Sold FS: Boston Z6, Polk MMC6500, JL Audio TR650CSI, 6" Linear Actuator
SentraStyle
Boston Acoustics Z6. I am selling a brand new set of Boston Acoustics Z6 6.5" Component speakers. These have never been opened and still sealed from the factory. These are the best that Boston makes. Looking for $400 for these.
Recommended Amplifier Power: 20-400 watts
Nominal Impedance: 3 ohm
Sensitivity [1 watt (2.83v) at 1m]: 90dB
Frequency Response (±3dB in car): 40Hz-22kHz
Polk Audio MOMO MMC6500. These are the MOMO series 6.5" component set from Polk Audio. These speakers are brand new and were only opened to take the pictures. I am looking for $150 for these speakers.
6-1/2" Diameter (16.51cm) Woven Carbon Fiber.
1" Diameter (2.54cm) Silk/Polymer composite dome
tweeter.
Overall Frequency Response: 43Hz - 25kHz
Nominal Impedance: 4 ohms
Power Handling (continuous): 125 watts
Power Handling (peak): 250 watts
Efficiency: 90 dB
Crossover: 2.6kHz 2nd order High & Low Pass
Voice Coil Diameter: Driver 1" (2.54cm)
Voice Coil Diameter: Tweeter 1" (2.54cm)
JL Audio TR650CSI. I have a set of JL Audio entry level TR650CSI 6.5" components. These would sound great just off radio power or even better with a small amp. These are brand new, and only opened to take the picture. I am looking to get $100 for these speakers.
6.50 in. / 160 mm Woofer, Injection-molded, mica-filled, polypropylene cone body
0.50 in. / 12 mm Tweeter, 1/2" textile dome diaphragm, integral phase plug, neodymium magnet, ferrofluid cooled and damped. Designed for flush or surface mounting.
Grilles Included
1.0 in. / 25 mm voice coil
flat-profile/ symmetrical-roll spider
butyl rubber surround
Crossover Networks: Natural roll-off low pass (woofer), 1st order high-pass circuit with electrolytic capacitor on tweeter. Polyswitch tweeter protection.
Continuous Power Handling: 50W Continuous
System Efficiency: 91.0 dB @ 1W/1m
System Nominal Impedance: 4 ohms
System Frequency Response: 59 Hz - 22 KHz ± 3 dB
6" Accele Linear Actuator. I picked up this 6" Accelevision Linear Actuator with the purpose of making a motorized amp rack. I just don't have time to put that much work into it, so I am selling it. This item has never been installed and is in like new condition. But because I did hook it up to power to make sure it works, it is not NIB. I am taking best offer on this.
I accept paypal (add 3%) or money order. I have perfect feedback on ebay (user ID: droopydogg), and references on some of the nissan forums that I'm normally on.
SentraStyle
SentraStyle
Kissimmee, Fl
civic si
