Sold FS: BNIB Fusion Power Plant 2000.1's
Team H&K
Master of the 12v Variety
I have a couple Fusion Power Plant 2000 watt mono amplifiers. These amps are linkable Class D amplifiers. There brand new in box and still factory sealed. They were bought for a competition vehicle and then went with bigger amps. So these are not needed now. So going to let them go very cheap. Looking for 240 each shipped and paypal fees included! If you have any questions please om me or post here. Thanks for you interest! Pics below.....
Superior Thermal Conductivity : PowerPlant amplifiers feature superior thermal conductivity ensuring heat dissipates efficiently
Rugged Amplifier Case : Single piece extrusion with seamlessly matched die-cast end caps which protects connectors and internal components
Over-sized Mounting Feet : The oversized mounting feet with their recessed holes provide secure and discreet fastening points.
Over-Sized Power Connection : Enlarged contact surfaces for high current connectivity
Stage 2 System Management Panel : Multi-function management panel enables you to refine the characteristics of the signal to suit your audio preferences.
Multiple Fuse Protection : Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
465 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
750 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1150 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
Linked Power Ratings @14.4VDC
1000 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1800 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
Max Power Rating: 2000 Watts
Max Current: 100A
Full Rated Power Distortion (Max) 1kHz: 0.45%
THD @ Rated Power 1kHz/100Hz: 0.3%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 12 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47K
Fuse Rating: 25A x 4
Also remember these amps are under rated, and they are very stable amps at a lower imp.
I need to look up the measurements on the amp, I will let ya know...
Still looking for the size without having to open a box to check, if not I have a buddy that I will see tomorrow that has these, I will measure his...
Team H&K
Team H&K
Indiana
Team H&K
