(4) Brand New Clarion DPX11500's
Looking for $300 each plus shipping. Package price would be $1100 plus shipping.
Specs:
1500 Watts of Maximum Music Power
800W × 1 Into 4 Ohms, 20Hz-20kHz @
1500W × 1 Into 1 or 2 Ohms, 20Hz-20kHz @
Adjustable Subsonic Filter, 10-80Hz
Remote Control Included
Input Voltage Selector
Precise Frequency Selector
Variable Bass Boost; 0-15dB @ 30-125Hz
Adjustable -12db/Oct. Low Pass Crossover, 50-250Hz
Gold Plated Connectors; RCA/Speaker/Power
Speaker Level Input
Dimensions 21 1/4" × 12" × 2 7/8"
CEA 2006 Power Ratings
1500W x 1RMS [2Ω@14.4 ≤1% THD+N]
800W x 1RMS [4Ω@14.4V ≤1% THD+N]
S/N 72dB (Ref:1W into 4Ω)
Extech 5MHz Dual Channel Multiscope 381295 Oscilloscope and Autoranging True RMS Digial MultiMeter - Brand New - $405 Free Shipping (lower 48) or Picked Up
This model (381295) is actually discontinued, but is better than the newer version (381295A). The only difference between the two models, is that the 381295 allows you to gather live data acquisition on to a computer via the RS-232 PC port, and the 381295A allows only saved frame shots to be uploaded on to a computer via a USB port. (Confirmed by a Extech Technician). You can call extech tech support if you chose to confirm this for yourself. Regular price is $500
• Easy to Use Menu Driven Operation
• Internal or External Triggering
• Auto or Manual Setup for Horizontal and Vertical Scaling
• Single Shot Mode
• Window Freeze Locks Waveform in the Display
• Roll Mode for Slow Repetition Waveforms
• Store and Recall Up to 16 Waveforms and Setups
• Sampling Time: 25MS/s Dual Channel; 50MS/s Single Channel
• 132 x 128 Pixel Super-Twist Two Level Backlit Display
• Data Hold and Low Battery Indication
• Multimeter Functions Include AC/DC Voltage, Resistance, Continuity,
Frequency, RPM, Pulse Width, and % Duty Cycle
• RS-232 PC Interface and Software for Transferring Waveforms and Data
Specifications: Oscilloscope
Bandwidth 5MHz
Max. Sample Rate per Channel 25MS/s (dual channel); 50MS/s (single channel)
Record Length 512 single shot; 256 all other modes
Sample Mode Single shot, Roll, Normal
Max Vertical Sensitivity 50mV
Max Input Voltage 600V DC or AC rms
Trigger Modes Auto, Normal, Single
Trigger Source Channel A, Channel B, External
Trigger Coupling AC, DC
Timebase 1?S to 5S
Input Impedance 1M½
Specifications: Multimeter
DC Voltage 0.001V to 1000V (0.3% basic accuracy)
AC Voltage (TRMS) 0.001 to 750V (50-20kHz bandwidth)
Resistance 0.001k½ to 5M½
Continuity Test voltage 1.7V; threshold 100 digits
Frequency 0.01Hz to 10MHz
RPM 240-60,000
Pulse Width 2?s to 500ms
Duty Cycle 25% to 75%
Dimensions 7.7x3.5x1.6” (195x90x40mm)
Weight 16.2oz (260g)
Power 4.8V Ni-MH Battery/120V 60Hz adaptor/charger
Term-LAB Dual Sensor SPL Meter Slightly used, comes with manual, cd, wires, etc. Looking for $750 with free shipping to lower 48 states.
Specs:
Speaker Level Input
• Single Shot Mode
Bandwidth 5MHz
Timebase 1?S to 5S
Input Impedance 1M½
RPM 240-60,000
