Sold FS: BNIB Boston imaging neo set
Hebrew Hammer
1 Boston imaging system neo .... 150 shipped
Do you know of a weblink with information available on these? I'm interested, and I tried searching for more info about this set on Google, and no luck.
Features
Imaging System with alloy dome tweeter
* The Type-M2’s 1-inch anodized alloy dome is extremely lightweight and ultra strong, for excellent transient response and low distortion.
* Quick-fit mounting cup simplifies installation by allowing all connections to be made by placing the tweeter in the cup.
* Separable and dockable crossovers make installation more flexible.
* Docks with Pro or stands alone.
Nominal Size
1-inch (25mm)
Cutout Size
1-3/4" (45mm)
RMS Power Handling
50 watts
Peak Power Handling
100 watts
Nominal Impedance
8 ohms
Frequency Response (Imaging mode)
8kHz-22kHz
Frequency Response (SPL mode)
3kHz-22kHz
Sensitivity
90dB (1 watt @ 1 meter)
FeaturesImaging System with alloy dome tweeter
Nominal Size
1-inch (25mm)
Cutout Size
1-3/4" (45mm)
RMS Power Handling
50 watts
Peak Power Handling
100 watts
Nominal Impedance
8 ohms
8kHz-22kHz
3kHz-22kHz
Sensitivity
Thanks aeon! That's the good stuff! 50w RMS, tho. I'll probably pass on these. I want a set of metal tweeters that can take some power and scream.
Nominal Size
1-inch (25mm)
Cutout Size
1-3/4" (45mm)
RMS Power Handling
50 watts
Peak Power Handling
100 watts
Nominal Impedance
8 ohms
8kHz-22kHz
3kHz-22kHz
Sensitivity
wow...u rock...thanks!!!!
here is the cheaper set on crutchfield for 149.00
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=430&i=065TYPES&c=3&tp=107&avf=N
dude....I have 487 watt's going to each of my tweeters....it's all in how you use it
487 watts going to each tweeter?? Daayum, would those be the tweet in your avatar? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm running my mids and tweets 2-way active right now, each speaker is getting 120w each. So these Boston's would be fine on that kind of power? I was actually considering trying out a set of Boston Pro60's, but if this might be a better option for my application, then I'd definitely be willing to give them a shot.
yes sir...those are the Genesis r1...scan ring rev variation...
don't see any problem with running that much power to them...keep in mind how much more efficient they are compared to a normal driver...plus 120 watts is only peak or constant power and not what a driver sees playing music... just keep the gain down and keep the driver in it's proper freq band and you'll be fine....
Hebrew Hammer
Hebrew Hammer
ST.Louis, MO
Hebrew Hammer
vegang
vegang
