Well it is time for this driver to go. It's been sitting on my bedroom floor for the past two years not doing anything but collecting dust (except the motor, which repels dust //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif). I thought about keeping it because...well, it's an Aura MR 15. B) The back of the motor has some scratches on it but the scratches aren' deep enough to where they go all the way through the paint. The front of the speaker is perfect. The only part of the speaker that has any flaws are the scuffs on the backplate/cover.
Anyway, it is a single 4 Ohm driver. There are two positive and two negative terminals - two per side but it is a single coil driver so don't get confused if you buy it and try to put the single coil in series or parallel because it won't work. The dual pos and neg terminals on it are there for wiring options only (like using dual 10 gauge to power the sub).
The specs on the sub are as follows:
4" aluminum voice coil
Aluminum alloy cone
800 watts RMS power rating
Fs: 20 Hz
Re: 3.3 Ohms
Qms: 8
Qes: .4
Qts: .37
Vas: 169 liters
Sd: 765 cm^2
Pics:
I'm asking $450 plus shipping. If you are looking at this driver you already know what they retail for ($1000+) and know about the custom tooling Aura did on this driver. I live in NC and can get shipping estimates for serious inquiries only. My email address is Nick@stereointegrity.com and my phone number is 704.996.0850.
Aluminum alloy cone
Fs: 20 Hz
Re: 3.3 Ohms
Qms: 8
Qes: .4
Qts: .37
Vas: 169 liters
Sd: 765 cm^2
Pics:
