FS: Aura / Aurasound MR15 / NS15
xcoldricex
Product Brand & Model:
Aurasound / Aura
Condition of all items:
Very good
Total Price: :
$599 obo + shipping
Shipping Terms: :
Will be calculated based on location.
Pictures: - Unless you are a Upgraded member, or your last 10 iTrader feedbacks are positive, you must post a picture of the exact item you are selling.
Additional info:
One of the best subwoofers I've heard. You will have a very difficult time finding a true high fidelity subwoofer with comparable performance and an even harder time finding any of these drivers new. This was never installed, just tested.
They are capable of significantly greater performance compared to their smaller brothers. The 4" VC will allow 800 watts RMS power and 3200 watts peak power. The massive magnetic structure will allow 50mm peak to peak linear xmax and 75mm peak to peak excursion. The driver weighs nearly 50lbs, which is ridiculous considering it uses NEODYMIUM magnets.
Specs: http://www.madisound.com/store/manuals/aurasound/NS15-992-4A.pdf
Here is a link to the drivers spec sheet. You will find that the driver's impedance is flat to 2.2KHz, which corresponds to the aluminum cone's first breakup. Although capable of massive displacement, it has an incredibly extended high frequency response due to its advanced motor and incredibly rigid cone. Honestly, you could probably use this as a lower midrange driver since it does not exceed 1% THD until ~8KHz, which affords the possibility to use a dedicated upper midrange driver.
If the quantitative data fails to impress you, consider that these drivers are used in Magico's >$100k Ultimate II loudspeaker system.
Unfortunately, I don't have a use for it right now. This is the NS15 but this one has the different super **** color changing dustcap and magnet. the paint on the end has a few light scratches from storage.
Originally $1000
feedback:
Mazdaspeed Forums
ClubRoadster.net
Car Audio | DiyMobileAudio.com | Car Stereo Forum
xcoldricex service thread
xcoldricex
xcoldricex
Ann Arbor, MI
xcoldricex
