FS: Atomic 5000 - $400 plus shipping
snoopdan
Banned
Atomic 5000 watt
* Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS 5000W @ 0.5 ohm
* RMS 4000W @ 1 ohm
* RMS 2000W @ 2 ohm
* RMS 900W @ 4 ohm
* Signal-to-noise ratio 90dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* Bass remote controller with telephone wire & click volume & blue LED
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:
* Continuously variable 0 � 18dB Bass Boost
* Built - in variable 0 � 18dB per octave x�over
* Power Consumption
* Size: 24.50� x 10.60� x 2.60�
In a strange state, plays for hours at a time then for some reason it goes into protect. No FETs are burned and the board looks flawless. All I can think it is a controller board that needs fixed or the thermal switch. Either way, both are cheap fixes.
400 plus shipping cost, I will pack it up nicely as I have shipped large amps before with no issues.
NO TRADES
Will be heavy shipping, but I'll provide all info, tracking numbers...etc
The shops name is in the back, and you're buying from snoopdan...I mean come on!
snoopdan
Banned
snoopdan
Louisville, KY
snoopdan
