Sold FS: Arc Audio, TC Sounds, Monitor 1, Alpine 9815
stupify
First of all I want to say that I know the pictures aren't that great and I'm sorry. The good camera I couldn't find and was stuck using this old pos.
Also why am I selling you ask? I'm not using any of it and want to build some HT towers that I'd use.
Monitor 1 amps
These were ARPA made. No crossovers
MK 4.70 (70x4, 220x2) $150.00
MK 2.70 (70x2, 220x1) $75.00
These are all cosmetically 9-9.5/10 The 4.70 needs two of the screws for the speaker terminals, but other wise is in great shape.
____________________________________________________
Arc Audio 2500 xxk amp $200.00
270x2 @4 ohms, 525x2 @2 ohms, & 1,050x1 @4 ohms bridged
# Highly efficent 4 layer PCB
# Uniquely designed high efficent power transformer
# Rated 500 amp power supply switching FET
# Rated 250 amp per channel output devices
# Variable speed fan control for quiet operation
# Power save mode for low level playing time with engine off
# Protection against: reverse voltage, over voltage, speaker short, and thermal overload
# Heavy duty construction
Amp goes straight into protect. It costs 150.00 from arc to get fixed. So you'd be paying $350 for this amp which is like brand new as the person I got it from Bought it new off ebay and it went straight into protection. He sold it to me as he didn't want to send it into arc and mess with everything. I just never got around to sending it in. I emailed the guys at Arc about getting it fixed and they can do it and its $150 shipped back. It still have the serial numbers etc on the bottom. I can send it right to Arc to save on the shipping as I would just have to leave a note in the box saying that its ok to send to the new buyer. I already talked to them about doing that and they didn't have a problem with that.
________________________________________________________
(2) TC sounds 2+ Motors $50 shipped each!!!
Both of the Motors have 8" baskets to go along with the motor. The baskets could use a repaint but aren't cracked and could be used again. Motor's were supposed to be for 10" or 12" subs but you can use them as 8's as they were custom drilled to make the baskets fit.
I got them from HawaiianBassHed who had them custom drilled so the 8" baskets would fit. TC or Scott at FI could recone them for you. I already talked to Kyle at TC and Scott at FI and both could be done for you.
I hope HawaiianBassHed doesn't get mad at me for using a couple of his pictures but here are the motors next to a DD 1008
________________________________________________________________
Alpine 9815 Cd player $200.00
# detachable, fold-down face
# 2-line color display with spectrum analyzer
# blue button illumination
# plays CDs, CD-Rs, and CD-RWs
# plays MP3 and Windows Media (WMA) files
# displays MP3 text
# CD Text with scroll
# 0-bit mute (mutes output when no audio signal is detected)
# MaxTune SQ tuner
# 12 FM/6 AM presets
# station title memory
# V-Drive hybrid MOSFET60 internal amp — high-current draw requires direct fused connection to your battery
# Bass Engine Pro (5-band parametric EQ, 6-channel digital time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
# Media Xpander
# i-Personalize — create customized Bass Engine setups and text greetings
# XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
# CD changer controls for Alpine Ai-NET changers only
# optional auxiliary input
# 4-volt front, rear, and subwoofer preamp outputs
# wireless remote
# clock
# 27 watts RMS/60 peak x 4 channels
# CD frequency response 5-20,000 Hz
# CD signal-to-noise ratio 105 dB
# FM sensitivity 9.3 dBf
I still have the box, manual, remote, etc from new. I have the manual but its at a cousins house. I just need to get that from him back.
Cdplayer was top of the line back in the day. Works great. I still don't want to get rid of it but I'm not using it so. Had the cdplayer in my daily driver with a wall with 2 custom made 18" TC sound spl subs. Deck never skipped once.
Ref's are as follows
This is just a little of the references I have. This isn't getting into ebay or car forums
http://www.sounddomain.com/ubbthread...rue#Post969223
http://www.sounddomain.com/ubbthread...rue#Post975913
http://www.sounddomain.com/ubbthread...rue#Post975113
http://www.sounddomain.com/ubbthread...rue#Post973201
http://www.sounddomain.com/ubbthread...rue#Post972910
I've dealt with all these guys from Sounddomain/caraudio.com/diymobileaudio
dreid / Orange Foci
yosef
loud_aurora(x2)
SPLfreak
uiplannerman
Version 13
J37X
SteveC
this_forum_did_me_wrong
professional
Morris
blazedagain
*BowDown*
Goin' Def
its_hey_ma
TheGame420
Split2nd Racing
Renegadesrun
HCCAfan
OkMariner
vitveet(x3)
bigaztec
bkoopman1
vibrator
slow2.2sonoma
skinrock
Mazda3SQ
HawaiianBassHed
http://www.caraudio.com/forum/showthread.php?t=145819
http://www.caraudio.com/forum/showthread.php?t=113112
http://www.caraudio.com/forum/showthread.php?t=111900
http://www.caraudio.com/forum/showthread.php?t=103339
I can get others if really needed
Prices again for those who can't read
Arc 2500xxk
$200 plus shipping
Monitor 1 amps
MK 4.70 (70x4, 220x2) $150.00 plus shipping
MK 2.70 (70x2, 220x1) $75.00 plus shipping
Alpine 9815 cd player
$200.00 obo plus shipping
TC sound 2+ motor with basket
$50 shipped EACH this is the only item with shipping included.
damm good deal on the 8"s I sold them to him, he's loosing money, and JUST got them from me. and in all honesty, I STILL want to see you use them man... trust me when I say they're loud and get low, I have had almost every 8" sub out, the loud ones at least and can tell you they will definetly shut alot of the others down on street bass, may not peak as loud on upper notes spl, but they definetly get loud and LOW. I have a pair of DD 8"s and I like those better... if you get them reconed and don't like them I'd be intrested in getting them back from you... have you checked with Scott @ FI if his X coils will fit? you could do a custom sub from him and I can tell you that his recones would be sick. I'm still waiting on a pair but when mine get here I'm sure I'll be more than happy with them, and will hope to sell the subs to get some FI BL's //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If they don't sell I might think about it but I could use the cash for the HT stuff I need.
What would the 8" cost to get reconed? I might be very interested in those.
To get them recone into 8's I dunno. I was going to make one a 10, and one a 12 so i would have needed a new basket so I don't know how much to make a 8. Scott will email you back at FI if you want custom from him or you can contact TC sounds and they will tell you also
I really don't have a preference with either. I've never had a sub reconed. So I was just wondering if I did purchased the baskets, what it would run me to have them reconed.
The baskets come with the motors for the $50 shipped price. I will contact TC and FI audio and ask what it would cost to use the baskets I have and motors to get them reconed. If you went with FI audio they would custom make the subs how you wanted if they had the parts. I dunno will TC will do custom subs anymore or not.
stupify
stupify
South Dakota
stupify
