Sold FS - Arc Audio 5150XXK
txbonds
I will have this in a few days. Seller ranked it a 9 out of 10. I've decided to do something differently and the 5 channel isn't going to work, so I'd just like to sell for what I paid. 45x4 & 190x1
Asking $250.00 plus shipping. Will consider small deposit to hold it and allow payment upon my receipt and checking of the amp.
References from prior sales on DIYMA and ebay..... same user name on both.
Please PM or Email me with interest or offers.
Possible trade items:
Arc Audio KS300.4
Stinger or similar 12 gauge twisted pair speaker wire
Arc Mini 125.2
Information available here: http://www.arcaudio.com/archives/xxk_amp.pdf
Pics of actual unit here:
Additional information I found:
Product Description:
* 5-Channel Amplifier
* RMS Power Rating:
o 4 ohms: 45 watts x 4 chan. + 190 watts x 1 sub channel
o 2 ohms: 75 watts x 4 chan. + 190 watts x 1 sub channel
o 4 ohms bridged: 150 watts x 2 chan. + 190 watts x 1 sub channel
* Remote bass boost control (0 - 18 dB @ 45Hz)
* Variable Bass Boost Frequency: 30Hz - 125Hz
* Transient distortion :
* Designed, Engineered and Assembled in the USA
* Various Protections: Short Circuit, thermal, reverse voltage, over voltage and DC offset
* Built-in variable 12 dB per octave Crossover
* 12db or 24dB per octave subwoofer crossover
* Crossover Range: 55Hz - 5.5kHz
* CEA-2006 Compliant
* Preamp output and Preamp input
* Very high damping factors
* 4 gauge power/ground leads
* Fully regulated power supplies produce full power output with battery voltages as low as 12 volts.
* Symmetrical, discrete power amplifier circuitry
* Engineered to drive highly reactive loads
* Microprocessor controlled power supply and protection circuits
* Dimensions: 16"L x 8"W x 3.35"H
▪ Microprocessor controlled ▪ Set and forget crossover switches on bottom plate ▪ Seperate front and rear high/low/full range select switch ▪ Seperate front and rear mono/stereo/full range select feature ▪ Heavy duty construction ▪ Thermal, DC, offset, reverse voltage, over voltage, short circuit protection ▪ Output power : 45x4 @4 ohms, 75x4 @2 ohms, 150x2 @4 ohms bridged & 190x1 @ for sub channel ▪ Transient distortion : 107dB ▪ Bass boost : + 15dB @45Hz ▪ Input sensitivity : 250mV - 2.5V ▪ Crossover : 12dB stereo, 24dB mono 55Hz-5.5KHz ▪ Dimensions : 16" x 8" x 2.35"
txbonds
txbonds
Florida
txbonds
