Fs: americanbass vfl extreme 12d4
  • 2
blkmrideon22s
Boone NC
American Bass VFL extreme Dual-4 Ohm 12
used There is 3 little scuffs on the surround but does not affect it at all can barley see them in person.
750 Watss RMS
180 Ounce Magnet
Efficiency: 91.75dB
Dual 3" 4 Ohm High Temperature Voice Coils.
Cast Aluminum Basket
1.4" Wide Multilayer Foam Surround for Better Stable Linear Exclusion.
Non-Pressed Black Treated Paper Cone.
Vented Deep Bumped Back Plate
180 Ounce Double Stacked Magnet Structure
Inverted Dust Cap further increases Cone's resistance to flex under Pressure
Dual Black Mirror-Image Spiders For Linear Stability.
Sleeved High Power Tinsel Lead Wires to resist Lead breakage.
Blackened Motor Parts for Superior Heat Dissipation & Long Life
Hyper extended Pole Piece Increases Accuracy, raises Induction.
Deep Bumped Back Plate to Increase Power Handling.
Uni-Rubber Gasket for Airtight Seal in Mounting.
$170 shipped
usps or ups
Without better photos it's hard to really see anything. Based off of those it looks just fine. Grab a digital multimeter, set it to continuity...
  • Locked
Great amp. Ran on nothing lower than 13.9 volts ever. Adult owned and never abused. Looks: 8 of 10. A few scratches due to being used...
I would assume it is the radio's built in eq curves that are meant to protect the OEM speakers. You will need a DSP with signal leveler. That...
962
blkmrideon22s
blkmrideon22s
Boone NC
blkmrideon22s
    May 12, 2024
Brendon Jenness
    May 11, 2024
