Sold FS:Alumapro15 Farad Cap,IDQ31s,Rainbow Profi 3way, US AMPS, Memphis Amp, Kenwood Amp
dinty01
160 deeeBeeeeess
Hey guys, Ive got some stuff for sale:
First up is a Limited Edition Chrome Alumapro 15 farad cap, it is nice although it has some scratches on the top from the previous owner, he was a rep for alumapro, I bought it feb-march of this year and never installed it, comes with the heavy duty relay and the small relay, it includes a Limited Edition plaque although it needs to be reglued, it fell off when it was shipped, I want $200 plus shipping for it, a very rare piece.
See www.alumapro.com for installation instructions and specs on the CAP.
Second is a set of Rainbow Profi speakers, it is a 3 way setup with both sets of crossovers, this is BNIB, I only took them out to take pictures. Includes the 6's, 4's and tweeters, mounting hardware for the tweeters and connecting hardware(screws and connectors I think), both sets of cross overs and the installation instructions from Rainbow(and yes some of the instructions are in English), I want $775 plus shipping for them.
And this is the CS365 kit
Rainbow's Website
Rainbow's Site for specs
more:
SOLD!!!!Third is a Memphis St-2004, it is a 4 channel amp, the rms power in 4 ohms is 50x4, the rms power in 2 ohms it is: 75x4, THD 2/4ohm:0.03%, S/N Ration:>92dB, Variable Low-Pass Filter:40-6Khz, Variable High-Pass Filter:40-6Khz, Filter Slopes: 18dB, Input Sensitivity: 250mV-5V, Input Impedance:22Kohms, Frequency Response +/- 1dB:10Hz-50KHz, Fuse Rating:40A x 1, Dimensions 6.5" x 2 " x 11.875". thats the specs from memphis's website, it is in pretty good condition, all the fins are straight but there is some scratches and nicks in the finish, it worked very well last time i used it, Im not quite sure what to ask for it, hows $50 plus shipping?
Fourth up is a Kenwood KAC-628 amp, it is used but not for very long, it is in excellent condition, it also comes with some wires for installation, a power wire(with inline fuse), a ground wire, remote turn on lead and wires to connect to the sub box(positive and negative inside the gray platic cover),heres some specs for it: max power output at 4 ohms, normal mode: 100 wattsx2, bridged mode is 300 wattsx1, rated power output at 4 ohms: normal( 20 Hz ~ 20 kHz, 0.08 % THD) 50 wattsx2, bridged( 1 kHz, 0.8 % THD) 150 wattsx1, rated power output at 2 ohms: normal( 1 kHz, 0.8 % THD) 75wattsx2, frequency response(+0, -1 dB) 10 Hz ~ 45 kHz, signal to noise ratio: 100 dB, sensitivity(MAX)(rated output) 0.15V, Sensitivity(MIN)(rated output) 4.0V, inpt impedance: 10 k(ohm symbol), low pass filter(12 dB/oct.) 80 Hz, high pass filter (12dB/oct.) 150 Hz, general info: operating voltage(11 ~ 16 V allowable) 14.4V, current consumption( kHz, 10 % THD) 19A, dimensions(WxHxD): 8 11/16 x 2 3/16 x 9 inches, weight is 5.9 pounds, thats all the info from the maunal that will come with the amp, Id like $45 plus shipping for it,
Fifth up is a set of 2 way crossovers for rainbow speakers, they originally came with the profi's but they arent needed any longer since a second pair came when i ordered the 3 way crossover set, they are NIB as well, Id like to get $45 plus shipping for them.
more:
Sixth up is my Image Dynamics IDQ 31's they are BNIB, I bought them to work with the rainbow's but since I wont be doing a SQ install I dont need these, they have never seen power, one is a master unit and the other one is a slave unit, I only have whats in the pictures, no manuals or connectors, I was supossed to get the manuals when the guy who bought the audio store I used to work at re-opened it, but then again I was also supossed to keep my job-that didnt happen either, anyways, if you need help assembly them you can go over to ID's forum and ask there and Matt, Carl, or Eric will be able to help you with it, I want $450 plus shipping, remember these are brand new never seen power!!
Seventh up is a US Amps SAT Reader, it was used once but my 2000x's no longer have SAT so it is of no use to me, it has 2 disks with it, I dont remember what is on them exactly, but I think one is an update to the older software, and Im also not sure if they will work with newer Operating Systems such as Windows XP, it can read the amp's model and serial number, date of manufacture, total hours, minutes and seconds the amp has ever been on, how often an individual channel has shorted, how often the vehicle battery has gone under or over voltage, and how often the amp has gone into thermal protection, SAT provides real time analysis for in car diagnostics, the ap can be remotely triggered on by SAT and at a glance the "Live Console" displays whether or not all amplifier systems are functional. That info is right off of the instructions that will come with the SAT, both cords( 1 goes to the computer and the other goes to the amp itself), all 4 disks and the instructions, I want to get $150 for it plus shipping.
All of this was going to go to Ebay but I thought Id offer it to the CA.com forum members first. I accept Paypal but the buyer will need to add on the 3% fee charge, I also accept money orders and certified checks, I DO NOT ACCEPT PERSONAL CHECKS!!! I only charge for shipping what the website says, I can ship the items through USPS or UPS, they have the best rates and I will ship them anyway youd like through either of those services. If youd like more pictures please let me know or if you have any questions feel free to email me: don.moore38@comcast.net, thanks for looking!!!!!
And Happy Thanksgiving!!!
thanks for the bump, im tryin to thin out the herd a bit and get rid of some of the stuff i probably wont use---Dinty
yea, thats what the manual says it puts out at 2 ohms, it was a good little amp, it was the first amp I bought, it powered a jl 10" w0 sounded good too, but i upgraded to my idq 12" and switched to a memphis amp but i now run the arc audio stuff, i can try to take a picture of the specs page if you want, lemme know---Dinty
can you do $35 shipped for it?
No I cant, Id do $35 plus shipping, but not including shipping, it weighs just about 7 poundsbefore being packaged up, I think its a good deal for a small amp, $35 is the lowest Ill go(plus shipping), lemme know if youre interested, thanks--Dinty
dinty01
160 deeeBeeeeess
dinty01
PA
dinty01
