I have two amps for sale. They are both used, the PDX4.100 is 9.5/10 (near perfect condition and the PDX1.1000 i'd say is an 8.5-9/10 (there are a few scuffs on the top and some other minor blemishes). Both amps are a 10/10 mechanical condition. The amps come with all the speaker plugs but I do not have the stacking hardware or the allen keys needed to tighten the speaker/power wire (but they are just standard allen keys and can be had anywhere). I am selling these because I aquired them for doing a #%$@ load of powder coating for a friend of mine as well as building a fiberglass box (so these were my payment for about 2 months worth of work). I need another amp like I need another hole in my head so I'd rather just sell them. I am also throwing in 2 runs of 4 awg. (red) power wire (one run is 18' and one is 9') each with an inline fuse holder, 2 (black) 4 awg. ground runs, a 9' nine-conductor speaker wire (FL/FR/RL/RR and remote run in a single jacket of wire), and 3 sets of stinger 2 ch rca cables (6'). Looking for $700 shipped for the pair (would prefer not to separate). Here are the specs:
Alpine PDX1.1000
Power Output: 1000 x 1 RMS @ 4 or 2 ohms (these amps typically do at least 10% more than rated power)
S/N Ratio: 110 dBA @ rated power into 4 ohms/80 dBA @ 1watt into 4 ohms
Input Impedance: 10k ohms
Frequency Response (200 Hz / -3dB): 20-200Hz
Crossover Frequency: Variable 50-200Hz (-24dB/octave)
Input Sensitivity: 0.1-8.0 Volts
Dimensions: 10-1/8" x 2-7/16" x 7-9/16" (will easily fit under seats)
Alpine PDX4.100
Power Output: 100 x 4 RMS @ 4 or 2 ohms or 200 x 2 RMS Bridged @ 4 ohms (again, these amps will typically do at least 10% more than rated power)
S/N Ratio: 96dBA @ rated power into 4 ohms/ 76dBA @ 1 watt into 4 ohms
Frequency Response (+0, -1dB): 20-20kHz
Crossover Frequency (Variable, LPF/HPF/Off selectable): Ch 1/2: 30-400 Hz; Ch 3/4: 30-400 Hz
Input Sensitivity: 0.2-4.0 volts
Dimensions: 10-1/8" x 2-7/16" x 7-9/16" (will easily fit under your other seat)
Alpine PDX1.1000
Alpine PDX4.100
