Sold FS/ Alpine MRP-F250 4 Channel amp
  • Thread starter Nova76
  • Replies 0
  • Views 341
Nova76
Alpine 4 channel amp MRP-F250 paid $500.00 a year ago retailes at $230.00
crutchfield review (Outstanding audio performance — you expect it when the amp is an Alpine. Alpine's V-Power amplifiers supply the high level of performance you want without shaking loose too much of your hard-earned cash.
The versatile MRP-F250 4-channel amplifier can take on a variety of roles in your system. Drive your front and rear speakers in 4-channel mode, or switch to 2-channel mode to power a couple of small subs. Want the best of both worlds? Use channels 1 and 2 to power full-range speakers, and bridge channels 3 and 4 to power a sub. Any way you use it, this amp will impress you with its strong sonic performance.
Variable high-pass/low-pass filters let you adjust the frequency output for either full-range speakers or a sub. If you're driving a subwoofer and using the low-pass crossover, a subsonic filter eliminates inaudible, ultra-low bass notes for cleaner output.
The amp's rugged construction ensures reliable performance. A heavy machined-metal heatsink keeps the internal parts cool and distortion low. Gold-plated screw terminals resist corrosion that can degrade signal performance.)
there are some mosfets that are blown on it replace those and your good to go im looking for $80 shipped retailes at 230 cost maybe 80 to fix unless you do it yourself so at the most 160 to get the amp and fix it and your good to go
Nova76
Nova76
Tucson, AZ
Nova76
