Sold FS: Alpine H701 - TC 5200 + 5400 - SS XXX - RE XXX - Big Belle - Boxes - Misc -
SPY
1. Product:
Alpine PXA-H701 + Alpine RUX-C701
2. Specs:
http://vault.alpine-usa.com/products/documents/OM%20PXA-H701.pdf
3. Description/Condition:
Used but in good working condition.
Includes H701 unit, power harness and Ai net cable, C701 remote unit, connecting cable and mounting cage. Mounting cage has been trimmed but should still work just fine or you can get a new one for about $15 at Appliance parts, electronics parts more from PartStore.com
4. Price: :
$550 shipped
5. Pictures:
1. Product: 2 8" TC 1000's DVC 4ohm
2. Specs:
• Double stacked 1" tall ferrite magnets
• 150oz motor structure
• 2" diameter, 4-layer aluminum wire voice coil
• xmax of 24mm (one way linear travel)
• Single poly-cotton spider with intergraded woven leads
• Cast aluminum basket with high gloss power coating
• Either single or dual 4Ω aluminum voice coil with four layers of wire
• 400 watts sustained (1000 watts dynamic)
• High quality thermal flexible epoxies to ensure longevity
• Rigid lightweight brushed aluminum cone
• Vented flared pole piece
• Copper shorting ring
• Rubber half roll surround allows for linear travel
• Dressed in a rubber magnet boot and gasket
• Hand built in our San Diego, CA factory
• Weighs in at 25lbs
Near mint, one sub has a pin size ding in the cone, so small I can't get a good pic of it.
4. Price: : $300 + shipping
5. Pictures:
1. Product:
12" Si Mag V4
2. Specs:
At first glance it is more compact than the average subwoofer. As a matter of fact, it is more compact than the average subwoofer. At only 5.5” total depth, it allows you to mount the new Mag v4 in an enclosure that is only 4.75” deep.** With its XBL^2 enabled motor it supplies you with only the most true, clean, deep, aural experience possible. Its soft parts have even been over-designed; using only the best technology such as a Kevlar composite paper pulp cone along with woven-on tinsel leads and a linear 8” diameter spider that allows for the utmost distortion-free operation possible. The all-new Mag v4. Great engineering is great engineering at any size.
D2ohm
BNIB
4. Price: :
$225 + shipping
5. Pictures:
1. Product:
15" Oz Audio Power series
2. Specs:
QVC 1ohm, 4000 rms/ 8000 max
PM me your email addy and I will send the manual in PDF
good condition
4. Price: :
$325 + shipping
5. Pictures:
1. Product:
New style 15" RE Audio XXX
2. Specs:
Technical Specifications - RE AUDIO
Good condition, DVC 2ohm, comes in original shipping crate
4. Price: :
$500 + shipping
5. Pictures:
1. Product:
15" TC Sounds 5200
2. Specs:
TC Sounds (TC-5200)
Good condition, QVC 1.2ohm
4. Price: :
$600 + shipping
5. Pictures:
1. Product:
15" LMS Ultra
2. Specs:
Audiopulse
Has blue AP basket and black TC Sounds cone, DVC 2ohm.
It does have some minor cosmetic flaws from damage due to shipping from the previous owner but it should not affect performance at all. There are some ripples in the center of the cone and a ding along the outer edge. I did my best to capture these flaws in the pics, they actually look worse in the pics than in person.
4. Price: :
$700 + shipping
5. Pictures:
1. Product:
Memphis MCH1300
also know as the Memphis Big Belle
2. Specs:
5-Channel MClass Series Amplifier
Class-AB / Class-D Hybrid Amplifier
Compact Aluminum Chassis with Custom Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz) (Channels 1-4)
Fully Variable Crossover: LP (50 Hz - 250 Hz), Subsonic (20 - 50 Hz) (Channel 5)
4-Way Protection Circuitry
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
Optional Wired Remote Gain Control
RMS Power Ratings:
75 watts x 4 chan. / 300 watts x 1 chan. @ 4 ohms
115 watts x 4 chan. / 600 watts x 1 chan. @ 2 ohms
1100 watts x 1 chan. @ 1 Ohm (ONLY CHANNEL 5 IS 1 OHM STABLE!)
Adjustable Input Sensitivity: 200mV - 4V
Dimensions: 25.81" L x 7.6" W x 2.4" H
Used but in good working condition. Has some minor marks on the top as shown in pic #2 and also has a small piece of plastic broken off the front right corner as shown in pics #1 and #3, I do have this piece so you can glue it back on if you wish.
4. Price: :
$400 + shipping
5. Pictures:
1. Product:
Box: 4.0ft^3 tuned 30hz for a single 15” sub
2. Specs:
Box is 45.5”w x 14”h x 17”d, 4.0ft^3 tuned to 30hz with a single 6” aeroport. Box includes 3 interchangeable baffles, 14.5, 14.25, 14.125 cutouts, installed using T-nuts. Aero was used in a previous box and had to be cut to get it out but it still works fine. Box is bare wood right now but I can carpet it in your choice of black, charcoal or light gray for an additional cost. Does not have a speaker terminal but I can add a basic one for free or a threaded rod and bolts setup at additional cost.
New
4. Price: :
$75 + shipping as-is
Add $25 for carpet
Add $5 for threaded rod and bolts speaker terminal
5. Pictures:
Picture doesn’t show the 2nd baffle or removable baffles.
1. Product:
Box 4.0ft^3 tuned to 30hz for a single 15” sub
2. Specs:
Box is 40”w x 14”h x 19.25”d, 4.0ft^3 tuned to 30hz with a single 6” aeroport. Box includes 3 interchangeable baffles, 14.5, 14.25, 14.125 cutouts, installed using T-nuts. Box is covered in charcoal carpet and had a light gray 2 tone carpeted logo on top. Has threaded rod and bolts for speaker terminals.
Used but looks new
4. Price: :
$200 + shipping
5. Pictures:
1. Product:
Box 2.27ft^3 tuned to 40hz for 3 8” subs
2. Specs:
Box is 34”w x 16”d x 14.5”h, 2.27 ft^3 net vol tuned to 40hz, designed for 3 DD 1508’s but will work for a lot of subs. Double front baffle with oval recessed cutout for the subs, kerfed port, white painted port and sub mounting area with black carpet. Screw type speaker terminal.
Used but in good condition
4. Price: :
$125 + shipping
5. Pictures:
1. Product:
Prefab box for 10” sub
2. Specs:
aprox 1ft^3 sealed box, gray carpet, speaker terminal, slanted front.
Had a sub mounted in it but never played.
4. Price: :
$10 + shipping
5. Pictures:
1. Product:
Red LED tube
2. Specs:
They are red
used but I was told they work fine
4. Price: :
$20 + shipping
5. Pictures:
1. Product:
Sundown Audio Banner
2. Specs:
2’x5’ ish
Brand new
4. Price: :
$45+ shipping
5. Pictures:
1. Product:
Orion sign
2. Specs:
Metal with Orion logo cut out of it
Excellent condition
4. Price: :
$35 + shipping
5. Pictures:
1. Product:
Sound Stream Grill
2. Specs:
15”
I was told it was new when I bought it, not sure that is true but it is in very good condition.
4. Price: :
$40 + shipping
5. Pictures:
SPY
SPY
NY
J31Rob
