Hello,
I am selling a 3 month old Alpine CDA 9851. I upgraded to the CDA 9855 and no longer have use for this. It has been taken care of, never abused nor neglected (high heat or extreme cold) It has minor scratches on the faceplate that do not inhibit the units operation in any way. All accessories are included as pictured. A 4 year extended warranty is included through Best Buy. I am asking $250 shipped anywhere in the continental US. Postal MO only please.
Here are the specs:
Key Features
• 50W MAX x 4 High Power Amplifier
• 3 PreOuts (2V)
• SAT Radio Ready
• Ready for iPod®
• Bass Engine®
-Subwoofer Level Control
-Bass Center Frequency Control
-Bass Band Width Adjustment
-Treble Center Frequency Control
• CD-R/RW Playback
• MP3/WMA Decoder/Playback
• MP3 Text Information Display
• QuickSearch Function (MP3 Files)
• CD Text, CD Text Display, CD Text Scroll
• Versatile-Link™ Ready
• MaxTune Tuner
• Regulated 1-Bit DAC
• SwingFace Mechanism
• Wireless Remote Control Included
• OEM Steering Remote Ready
• Detachable Trim Plate
• Anti-Theft Detachable Front Panel
The CDA-9851 is a SwingFace head unit with a wide range of sound personalization functions from Alpine's signature Bass Engine controls. In addition to playing all CD's, MP3 and WMA discs, now you can drive your iPod. Just hook up the KCA-420i iPod interface adaptor, plug in your iPod, and you're ready to go. Plus it's Versatile-Link Ready so you've got the option of connecting a video game console, VCR, or other source, This unit is OEM Steering Remote Ready so you can still control your head unit conveniently from your steering wheel. (3rd party adaptor required).
About Satellite Radio Ready:
You have the option to choose between Sirius Satellite Radio or XM Satellite Radio. SAT Radio Ready units require optional receiver box, antenna, adaptor cables, and subscription for service. To find out more about subscribing or available channels visit http://www.sirius.com and http://www.xmradio.com
Alpine does not recommend using hybrid digital media discs with "CD-like audio" on one side and DVD on the other in Alpine players. The "CD-like" side does not conform to the Compact Disc Digital Audio specification. At this time Alpine does not know if the use of these hybrid discs will result in damage to the discs or the players. Alpine will update this notice based on further software and product testing and or Industry standard updates.
Features:
CD Changer Control
* CD Text Display/Scroll
* Disc Play/Pause
* Disc Title Memory
* Forward/Backward
* M.I.X. One (Random Play)
* M.I.X. One/All (Random Play One or All)
* MP3 Changer Ready (CHA-S634)
* MP3 Text Information Display (ID3 Tag)
* Multi-CD Changer Control (with KCA-410C)
* Music Scan/Repeat
* Music Sensor Up/Down
* Quick SearchTM Function with MP3 Playback Changer (CHA-S634)
* Repeat
CD Player
* 18 Disc Title Memory Display (CD Only)
* CD Text, CD Text Display, CD Text Scroll
* CD-R/CD-RW Compatibility
* Digital Servo
* Disc Play/Pause
* Forward/Backward
* M.I.X. One (Folder)/All (Random Play) Music Scan/Repeat
* MP3/WMA Decoder/Playback
* Music Scan/Repeat
* Music Search Function
* Music Sensor (Up/Dn)
* Quick SearchTM Function (MP3 files)
* Regulated 1-Bit DAC
* Zero Data Mute (0 bit Mute)
General-Head Units
* Bass Band Width Adjustment
* Bass Center Frequency Control
* Subwoofer Level Control
* Treble Center Frequency Control
* Anti-Theft Detachable Front Panel
* Audio Interrupt In
* Audio Mute
* BBE Processor
* Bass Engine®
* CD Shuttle Control Function
* Clock
* Demo Function
* Detachable Trim Plate
* Dimmer-on Input
* Fader & Balance Controls
* OEM Steering Remote Ready
* Power Antenna Lead
* Remote-on Lead
* Rotary Encoder Volume Control
* Separate Bass & Treble Control
* Silver Face w/Blue Illumination Buttons
* Swing Face Mechanism
* Versatile Link Ready
* Wireless Remote Control Included
SAT Radio Control
* Category Search
* Preset Memory, 3-Bands (18 Channels Total)
* Quick SearchTM Function (Channel Selection)
* SAT Radio Text Scroll
Tuner
* Auto Memory
* Dual Region Tuner Capability
* FM Stereo Indicator
* Local/DX Selection
* MaxTune Tuner
* Preset Stations (FM:12/AM:6)
* Station Title Memory
* Title Search Menu/Scroll
* Up/Down Seek
Specs:
AM Tuner
* Tuning Range : 530-1, 710kHz
* Usable Sensitivity (IEC Standard) : 22.5/27.0 (µV/dBf)
Bass Engine®
* BBE® Modes : On/Off
* Bass Band Width Adjustment (Q) : 4 choices (1=Wide, 4= Narrow)
* Bass Center Frequency (Selectable) : 60Hz, 80Hz, 100Hz, 200Hz
* Bass Level Control Range : +20dB to -14dB at 60Hz (2dB Steps)
* Subwoofer Level Adjustment Range : -15dB to 0dB (1dB steps)
* Treble Center Frequency (Selectable) : 10.0kHz, 12.5kHz, 15.0kHz, 17.5kHz
* Treble Level Control Range : +-14dB at 10.0kHz (2dB Steps)
CD Player
* Channel Separation (1kHz) : 85dB
* DAC Type / Number of DACs : Regulated 1-Bit
* Dynamic Range (1kHz) : 95dB
* Frequency Response : 5-20k Hz (±1 dB)
* Oversampling : 8X/352.8kHz
* Sampling Rate : 44.1kHz
* Signal-to-Noise (S/N) : 105dB
* Total Harmonic Distortion (THD) : 0.008% (at 1kHz)
* Wow & Flutter (%WRMS) : B.M.L
FM Tuner
* 50dB Quieting Sensitivity : 13.5 dBf(1.3µV/75 ohms)
* Alternate Channel Selectivity : 80.0dB
* Capture Ratio : 2.0dB
* Mono Usable Sensitivity : 9.3dBf (0.8µV/75 ohms)
* Signal-to-Noise (S/N) : 65.0dB
* Stereo Separation : 35.0dB
* Tuning Range : 87.7-107.9MHz
General-Head Units
* CEA-2006 Power Rating (4Ohm@14.4V
* Chassis Size (W x H x D)in : 7"x2"x6"
* Chassis Size (W x H x D)mm : 178mm x 50mm x 160mm
* Maximum Mounting Angle : 30° from Horizontal
* Maximum Power Output : 50W MAX x 4
* Nose Piece Size (W x H x D)in : 6-11/16" x 1-13/16" x 11/16"
* Nose Piece Size (W x H x D)mm : 170mm x 46mm x 18mm
* Power Requirement / Fuse Type : 14.4V DC (11 –16 V allowable) / 15A (ATC)
* Pre Output Voltage (Before Clipping) : 2V
Remote Control
* Battery : (2) AAA size
* Dimensions (W x H x D)in : 1-21/32" x 4-25/32" x 29/32"
* Dimensions (W x H x D)mm : 42mm x 121mm x 23mm
* Model Number : RUE-4202
* Weight : 50g (1.80z)
Rockford Fosgate Punch 400S 2 channel amp $75 dollars (postal MO only) shipped anywhere in the continental US. The amp is sold as is. It is fully functional, however, I dont have the box, manual or the remote bass knob.
Pictures included
Please PM me with any questions
Here are the specs:
Key Features
• 3 PreOuts (2V)
• SAT Radio Ready
• Ready for iPod®
• Bass Engine®
• CD-R/RW Playback
• MaxTune Tuner
Features:
CD Changer Control
* Disc Play/Pause
* Disc Title Memory
* Forward/Backward
* Music Scan/Repeat
* Repeat
CD Player
* Digital Servo
* Disc Play/Pause
* Forward/Backward
* Music Scan/Repeat
General-Head Units
* Audio Mute
* BBE Processor
* Bass Engine®
* Clock
* Demo Function
* Dimmer-on Input
* Remote-on Lead
SAT Radio Control
* Category Search
Tuner
* Auto Memory
* MaxTune Tuner
* Up/Down Seek
Specs:
AM Tuner
Bass Engine®
CD Player
FM Tuner
General-Head Units
Remote Control
Pictures included
