Sold FS: Alpine CDA-9821...give me an offer
electronicsgeek
This HU has about 6-8months of use. Works in perfect condition. No cosmetic defects. Everything is included in the pics below. Give me a offer and ill see what i can do.
it doesn't have an active crossover does it?
Features:
CD Changer Control
Disc Play/Pause
Forward/Backward
M.I.X. One (Random Play)
Music Scan/Repeat
Music Sensor Up/Down
CD Player
CD-R/CD-RW Compatibility
Digital Servo
Disc Play/Pause
Forward/Backward
M.I.X. (Random Play)
Music Scan/Repeat
Music Sensor (Up/Dn)
Regulated 1-Bit DAC
CD Shuttle Control
Disc Play/Pause
Forward/Backward
Music Scan/Repeat
General-Head Units
Bass Band Width Adjustment
Bass Center Frequency Control
Bass Type Control
Subwoofer Level Control
Treble Center Frequency Control
1 PreOut
Anti-Theft Detachable Front Panel
Audio Mute
Bass Engine®
Black Face w/Green Illumination Buttons
Detachable Trim Plate
Fader & Balance Controls
Loudness
Power Antenna Lead
Remote-on Lead
Rotary Encoder Volume Control
Separate Bass & Treble Control
Versatile Link Ready (M-Bus)
Tuner
Auto Memory
Local/DX Selection
MaxTune Tuner
Preset Address Indicator
Preset Stations (FM:12/AM:6)
Up/Down Seek
Specs:
AM Tuner
Tuning Range : 530-1,710kHz
Usable Sensitivity (IEC Standard) : 22.5µV/27.0dB
Bass Engine®
Bass Center Frequency (Selectable) : 60Hz, 80Hz, 100Hz, 200Hz
Bass Level Control Range : +-14dB at 60Hz (2dB Steps)
Bass Type (Selectable) : Off /Type1 / Type2 /Type3
Bass Width Adjustment (Q) : 4 choices (1=Wide, 4= Narrow)
Subwoofer Level Adjustment Range : -15dB to 0dB (1dB steps)
Treble Center Frequency (Selectable) : 10.0kHz, 12.5kHz, 15.0kHz, 17.5kHz
Treble Level Control Range : +-14dB at 10.0kHz (2dB Steps)
CD Player
Channel Separation (1kHz) : 85 dB
DAC Type / Number of DACs : Regulated 1-Bit / 2
Dynamic Range (1kHz) : 95 dB
Frequency Response : 5-20k ±1 dB
Oversampling : 8X/352.8kHz
Sampling Rate : 44.1kHz
Signal-to-Noise (S/N) : 105 dB
Total Harmonic Distortion (THD) : 0.008% (at 1kHz)
Wow & Flutter (%WRMS) : B.M.L
FM Tuner
50dB Quieting Sensitivity : 13.5 dBf(1.3µV/75 ohms)
Alternate Channel Selectivity : 80.0 dB
Capture Ratio : 2.0 dB
Mono Usable Sensitivity : 9.3dBf (0.8µV/75 ohms)
Signal-to-Noise (S/N) : 65.0 dB
Stereo Separation : 35.0 dB
Tuning Range : 87.7-107.9MHz
General-Head Units
Chassis Size (W x H x D)in : 7"x2"x6-1/4"
Chassis Size (W x H x D)mm : 178mm x 50mm x 160mm
Maximum Mounting Angle : 30° from Horizontal
Maximum Power Output (Note 1) : 45W MAX x 4 High Power Amplifier
Nose Piece Size (W x H x D)in : 6-3/4" x 1-13/16"x 11/16"
Nose Piece Size (W x H x D)mm : 170mm x 46mm x 18mm
Operating Temperature (°C/°F) : 60°C (140°F) to -10°C (14°F)
Power Output : 16W x 4*
Power Output Measurement : 4 Ohms and Š1% THD+N
Power Requirement / Fuse Type : 14.4V DC (11 –16 V allowable) / 15A (ATC)
Pre Output Voltage (Before Clipping) : 2 Volts
Signal to Noise : 80dBA (reference: 1W into 4 Ohms)
Weight : 1.5kg (3lbs. 5oz)
electronicsgeek
electronicsgeek
US
electronicsgeek
