Got a pm about the specs so I'm going to post them here:
FEATURES
General
Remote Control: Remote Control Included
Mute: Built-in Audio Mute
Audio Interrupt: Audio Interrupt Input
Remote Turn-On: Amplifier Remote Turn-On Output
Power Antenna Lead: Power Antenna Output
Dimmer: Dimmer Input
Detachable Face Plate: Detachable Face Plate
DIN Trim Plate: Detachable Trim Plate
Clock: Built-In Clock
Fader & Balance: Fader & Balance Controls
Bass & Treble: Bass & Treble Controls
Steering Wheel Control: Steering Wheel Control Ready
Auxiliary Input: Versatile-Link Ready
DAC: 24-Bit DAC
Bluetooth®: Bluetooth Ready
PreOut: 3 PreOut (4V PreOut)
Easy Navigating: Quick Search
Playback: MP3/AAC/WMA Playback
Illumination Buttons: Blue
Face Color: Gunmetal Black
Control Type: Rotary Encoder Knob
Display: 2 Line Biolite Display
CD Changer: CD Changer Control
Power Output: 50W x 4 High Power Amplifier
CD Changer Control
Repeat: Song/Disc
Music Control: Play/Pause/Forward/Back
Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
Multi-Changer Control: Multi-Changer Control Including MP3 Changer CHA-S624, (with KCA-410C)
M.I.X.: One/All (Shuffle)
Sound Tuning
IMPRINT: IMPRINT Sound with MultEQ Acoustic Correction (KTX-100EQ)
Crossover: Built-In High-Pass/Low-Pass Crossover
Equalizer: Built-In Graphic/Parametric Equilizer
Time Correction: Built-In Time Correction
MediaXpander: Built-In MediaXpander
Treble Level: Treble Level Adjustment
Treble Center Frequency: Treble Center Adjustment
Bass Level: Bass Level Adjustment
Bass Width: Treble Level Adjustment
Bass Center Frequency: Bass Center Frequency Adjustment
Subwoofer Level: Subwoofer Level Adjustment
Disc Player
M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only)
Title Memory: 18 Disc Title Memory Display (Disc Only)
Playback Control: Play/Pause/Forward/Back
Music Sensor: Scan/Repeat
Digital Servo: Digtal Servo
Zero data Mute: 0 Bit Mute
DAC: 24-Bit DAC
Music Playback: MP3/AAC/WMA Playback
Disc Playback Type: CD/CD-R/CD-RW
Disc Type: CD Player
Satellite Radio
Portable Compatibility: SIRIUSPlug N Play Devices (Adapter Required)
Music Information: Category, Artist, Song
Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
Satellite Provider Capability: SIRIUS or XM Adapter Required
Connection: SIRIUS or XM
Built-In or Ready: Satellite Radio Ready
Connection for iPod®
Information Display: Artist, Song, Album
Percentage Search: Percentage Search
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Playlist
Music Control: Song Up/Down/Repeat
M.I.X. (Shuffle) Capability: Song, Albums, All
iPod Compatibility: Full Speed Connection: iPhone, 4th/5th Gen. iPod Video/Photo, iPod mini and iPod nano
Source Type: Dedicated iPod Source
Connection: Full Speed Cable (KCE-422i)
Connection Type: Full Speed Connection for iPod®
Bluetooth®
Streaming Music Control: Streaming Music Control
Streaming Music: Streaming Music Playback
Phone Book: Phone Book Transfer
Hands Free: Hands Free Calling
Connection: Alpine KCE-300BT Required. Features may differ between phone model and service providers.
Built-In or Ready: Bluetooth Ready
HD Radio™
Multi-Casting: Multi-Cast HD1, HD2, HD3
Signal Switching: Automatic Digital/Analog
Status Indicator: HD Radio Satus Indicator
Connection: Alpine TUA-T500HD Required
Built-In or Ready: HD Radio Ready
Tuner
Seek Mode: Local/DX Selection
Memory: Auto
Memory Presets: Preset Stations (FM:12/AM:6)
SPECIFICATIONS
General
Weight: 1.6kg (3lbs 8oz)
Maximum Mounting Angle: 30° from Horizontal
Operating Temperature ( °C/ °F): 60 °C (140 °F) to -10 °C (14 °F)
Pre Output Voltage (Before Clipping): 4V
Power Requirement: Power Requirement: 14.4 (11-16) V.DC
Dimensions
Nose Piece Size (W x H x D) in: 6-3/4'' x 1-13/16'' x 15/16''
Nose Piece Size (W x H x D) mm: 170mm x 46mm x 24mm
Chassis Size (W x H x D) in: 7'' x 2'' x 6-1/4''
Chassis Size (W x H x D) mm: 178mm x 50mm x 160mm
Din Size: 1
Remote Control
Weight: 1.5kg (3lbs. 4oz.)
Dimension (WxHxD) in: 1-21/32'' x 4-25/32'' x 29/32''
Dimension (WxHxD) mm: 42mm x 121mm x 23mm
Battery Type: AAA Batteries (2 pcs.)
Model Number: RUE-4202
Included/Ready: Included
Sound Tuning
IMPRINT: Automatic Acoustic Correction & Computer Interface (KTX-100EQ Required)
Crossover: Flat/6/12/18/24dB oct., 20-200Hz (High-Pass/Low-Pass)
Time Correction: Adjustable 6 Ch. Time Correction (L-F/R-F/L-R/R-R/L-SW/R-SW)
Equalizer: 5 Band Parametric (20Hz - 20KHz, 1/3 oct. Steps), 7 Band Graphic
MediaXpander Aux Settings: MP3, Music, Movie, (Level 1, Off)
MediaXpander Modes: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off)
Treble Level Control Range: +/-14dB at 10kHz
Treble Center Frequency: 10k/12.5k/15k/17.5kHz (Selectable)
Bass Level Control Range: +/-14dB at 100Hz
Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
Bass Center Frequency: 60/80/100/200Hz (Selectable)
Subwoofer Level Adjustment: -15dB to 0dB (1dB steps)
Number of Channels: 2-Channel (Stereo)
AAC Decoding: ACC-LC format ''/m4a'' file
WMA Decoding: Windows Media™ Audio
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
Disc Player
Audio Signal-to-Noise (S/N): 105 dB
Oversampling: 8x/352.8kHz
Wow & Flutter (%WRMS): B.M.L.
DAC Type: 24-Bit DAC
Total Harmonic Distortion (THD): 0.008% (at 1kHz)
Dynamic Range (1kHz): 95 dB
Channel Separation (1kHz): 85dB (at 1kHz)
Frequency Response: 5-20k ±1 dB
AM Tuner
Usable Sensitivity (IEC Standard): 22.5/27.0 (µV/dBf)
Tuning Range: 530-1, 710kHz
FM Tuner
Capture Ratio: 2.0 dB
Stereo Separation: 35.0 dB
Signal-to-Noise (S/N): 65.0 dB
Alternate Channel Selectivity: 80.0 dB
50dB Quieting Sensitivity: 13.5dBf (1.3 µV/75 ohms)
Mono Usable Sensitivity: 9.3dBf (0.8 µV/75 ohms)
Tuning Range: 87.7-107.9 MHz
Max Power Output Ratings
Max Power Output: 50W x 4
CEA-2006 Power Ratings
CEA-2006 Power Rating: 4 Ω @14.4V ≤1%THD+N, S/N 80dBA (ref.1W into 4 Ω), 18W x 4
