Sold [FS] alpine 9884, MA SY7011DX amp, two 12" R.U. hardtimes, redtop, 6x9's, & more!
crunklech
captain crunch
VA
I recently just took out my whole system and trying to sell it all for tattoo money, not looking for trades since i already have anything i need... unless you can tattoo for car audio equipment then we could work out something. It is all in perfect working order and was never abused. I can do paypal or personal checks. The prices are not shipped, shipping is determined by how many items you buy and how far away you live. I can also do pick up or meet you somewhere. I will sell everything listed together as an entire system for 365 plus shipping (you can choose if you want the box or not, it will just add on more shipping). Now for the equipment i have for sale:
1) Alpine 9884 headunit; i bought this new and used it since last october, this is a great and reliable headunit. It is imprint compatible which is a plus for more advanced users. It also ipod compatible which allows you to control, search, charge, and play your ipod all through the buttons on the face plate. It comes with the harness (not pictured) and the face plate case. It is in pristine condition with no blemishes. *sold*
2) MA audio SY7011DX monoblock amplifier; i bought this used in october and used it to power my two twelves. It works great and has normal wear and tear marks on it. It has a digital screen on it which displays temp, volts, etc. It has 0g terminals which is always nice. It comes with a very sturdy bass knob made out of metal. I had it running at 1 ohm daily with no problems ever, never went into protection once the entire time i had it. Here are the factory specs on it: RMS Power @ 14.4V 4 Ohm 750W, 2 Ohm 1000W, 1 Ohm 1500W. Signal to Noise Ratio >96dB. THD Level 4 Ohm 0.5%, 2 Ohm 0.5%, 1 Ohm 1.0%. Frequency Response 10Hz - 350Hz. 24dB Low Pass Filter 50Hz - 350Hz. 24dB Subsonic Filter 15Hz - 50Hz. Bass Boost Control at 45Hz. 0 - 18dB. RCA Input Sensitivity 0.2 - 8V. Low level Input Impedance 22K Ohms. Damping Factor 200 @ 4 Ohm. Fuse Rating 40A x 4 Dimensions. (W x H x L) 11.6 x 2.56 x 16.73. looking for $160
3) two Robot Underground 12" hardtimes; i bought these new in october and these subs are awesome. Superior build quality just like you would expect from patrick at RU. these are d4 configuration so you can wire both of them together to achieve a 1 ohm load. They are rated at 650 watts RMS a piece. Look up ebay item #220360925451 to look at all the specs. That is for the 10" model because i cant find the 12", but its the same motor and basket. They have never been clipped or abused, and i have never got any funny smells or smoke come out of the box ports. Still in perfect condition and It comes with two free wire grilles. looking for $125 on both.
4) optima redtop 34/78; i bought this battery new in october and it has never been abused. It still holds a charge perfectly fine and comes with front terminal screws. looking for $70
5) wiring; two runs of 4g wire, the red run has a RF fuse holder with 100A fuse in it. I also have two sets of monster 101 XLN RCA cables (only one pictured). They are extra low noise and are twisted/shielded and feature gold contacts. Will throw in a roll of free speaker wire as well if you buy these. Looking for $50
6) ported enclosure for two 12"s; I built these for my kicker CVR's and then ended up using them for the hardtimes. It was tuned to mid thirtys, cant remember the exact Hz. It worked perfect and gave it that extra boom you always want. I did the splatter paint job and the stencil work just for looks. Made for 3/4" MDF and sealed all around with no leaks. *gone*
7) two pioneer 6 x 9's; they are TS-A6962R. These are decent speakers for anyone looking just to upgrade from stock. Still in perfect condition and comes with the grilles. *sold*
worked fine for me, but if thats the case i would hate to hear it with out the cancellation. I had the speakers wired together in parallel off a speaker wire block that was hooked up to the amp with the same length wire to each sub. I would figure that would atleast help some of the off phase
please ask me if you need any more pics of anything... here is a pic of the grilles that im including and a close up of the alpine...
crunklech
captain crunch
crunklech
VA
grooverider
