got this from a member and decided to go a diff.route.everything works great.heres the thread...http://www.caraudio.com/forum/showthread.php?t=241417
heres what he said...I would like to get $180 for this h/u, only $7 more and you can have the aux imput cable tha cooks via Ai net and has 2ch rca plugs for an input.
It does come with a cage, It does come with a remote.
There is no rubber ring around the volume knob either, when i recieved it the rubber ring had expanded causing the volume knob to not pop out, i just removed it so it would work.
It works flawlessly, plays scratched CD's just fine..if you tend to scratch them
This h/u will do active 3 way active crossovers.
Id give it a 9/10 because the rewind/fastforward buttons are faded. You can see them fine at night.The face itself has no scratches on it and it folds out smoothly.
Here's some specs off crutchfield about it:
FantomFace XL motorized stealth faceplate
MaxTune SQ tuner
plays MP3 files on CD-R and CD-RW, plus audio CDs, CD-Rs, and CD-RWs
MOSFET50 internal amp
XM Satellite Radio controls
Bass Engine Pro (5-band parametric EQ, 6-channel time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
Media Xpander
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
4-volt front/rear/subwoofer preamp outputs
clock
wireless remote
20 watts RMS/50 watts peak x 4 channels
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
http://www.crutchfield.com/S-alBOOO1l8tq/cgi-bin/ProdView.asp?I=500CDA7897
http://vault.alpine-usa.com/products/documents/OM_CDA-7998.PDF
i paid $185 shipped and would like to get that back.
it comes with headunit,trim ring,remote,cage,and aux.input.
click the link above for pics or i'll post them in alittle while.
MaxTune SQ tuner
Media Xpander
clock
wireless remote
