Sold FS: _____Phoenix Gold Xenon X1200 Mono Amp____
  • Thread starter tde46
  • Replies 0
  • Views 432
tde46
Hello,
This is a great and powerful amp. It's one of the best amp I've owned. Only selling because I have a child and the wife said it has to go.
The amp was used for 6 months to powered a single Alpine Type R. There is NO scratches or dents. It's in great condition. Please contact me with any questions.
Sale Price: $400 obo (Paypal: tde46@comcast.net)
I still have the original box and LPL44 (bass gain control) is included.
Check out my 100% feedback on Ebay. Username is: tde46
Descriptions:
Xenon amplifiers feature XeLOAD, which is a speaker impedance sensing circuitry that dynamically links the amplifier output to the speaker's resistance to insure full power on any load from 4 ohms down to 1 ohm. Xenon amplifiers will produce the same power regardless of the speaker impedance - a 600-watt Xenon amplifier produces 600 watts into 4 ohms, 2 ohms, or 1 ohm.
The monoblock Xenon amplifiers feature Class D technology for high efficiency and greater power output. Massive heat sinks combined with a variable speed (on the two top models) forced cold air intake system keep the operating temperatures low, and the event the amp does get hot under continuous high output operation, the proprietary XeFLOW cooling system insures that the amp will never cycle off while the music is playing, regardless of the operating conditions. Finally, each Xenon monoblock features 24dB Linkwitz-Riley low pass and subsonic crossovers. All three amplifiers have Remote Monitoring Display (RMB) Ports and are Low Pass Level Control ready (LPL44).
Features:
* 1200 Watts RMS Power Handling
* 1200 Watts X 1 @ 4 ohms
* 1200 Watts X 1 @ 2 ohms
* 1200 Watts X 1 @ 1 ohm
* 24 dB / Octave Crossover
* 4 Ohms Maximum Power Output
* Twin-T Variable 0 / 18 dB Bass Boost at 45 Hz
* Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
* 4 Gauge Power Terminals with Removable Rubber Grommets
* XeTUNE- Advanced input and signal processing circuitry
* XeFlow- Thermal feedback system with output optimization
* Auxiliary Outputs Route Full Range Signals
* Bottom-Mounted Extruded Aluminum Heatsink
* Expanded Metal Mesh Intake & Exhaust Vents
* Ultra-Quiet Variable Speed Fan
* Temperature Monitoring with Automatic Output Optimization
* LED Power Indicator
* Load Sensing Optimizes Power Supply and Output Stage
* Class D Circuit Topology For Less Electrical System Strain
* Dimensions: 22 W x 10.6 L x 2.5 H
tde46
tde46
Portland, OR
tde46
