Sold FS: 600rms x 2 bridged for $120 bones+sh
Fast1one
This MAY be up for trade, but the other party seems uninterested, so here it is:
Cadence TXA-6004 with a slightly bent foot and a couple hairline scratches. Still mounts normal and scratches are barely noticeable, if at all from a distance. Works well and has seen little abuse from me. Looking for a stealthier install //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Here you can see the biggest scratch, about 3 inches in length but pretty thin. You can't really see the scratches until you get closer. Its actually quite a beautiful amp IMO. And I am usually not a fan of chrome.
And here is the green light //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well what am I going to do with all these bones now? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
We are going to play the waiting game, receive payment, send payment, net gain = 0 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Net sound stage gain, priceless //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Also, anyone see a problem running 2 sets of speakers on 2 channels. My idea is to run my Front and rear parallel for 2ohms and run my subs on the other two channels. 4 ohm speakers, D4 ohm subs. Could be the most perfect setup I could imagine.
PM me with price shipped to 79707 and possibly the physical dimensions and we may have a deal. Have to make sure it would be comfortable under my seat. Does it run hot?
TXA-6004
4 CHANNEL HIGH POWER AMPLIFIER
SPECIFICATIONS:
4 Ohm RMS Power: 4 x 150 Watts @ 13.8 Volts
2 Ohm RMS Power: 4 x 300 Watts @ 13.8 Volts
4 Ohm Bridged RMS Power: 2 x 600 Watts
Frequency Response: 20Hz - 30kHz
Damping Factor: >200 @ 100Hz
S/N Ratio: >100 db
Channel Seperation: >65dB
Minimum THD:
Dimensions: 25" x 9.2" x 2.12"
FEATURES:
High Speed Mosfet Power Supply
Studio Grade Bipolar Output Stage Transistors
Fully Adjustable 18dB/Octave Crossover
Fully Adjustable Bass and Treble EQ Controls
Adjustable Input Gain 170mV-5V
Ultra Reflective Chrome Top Cover
2 Ohm Stereo Stable
4 Ohm Mono Bridgeable
3 Channel Mixed-Mono Capable
Power and Protection LED Indicators
Full IC Controlled Protection Circuitry
Mute and Soft Delay Circuitry
Lucite Encapsulated Terminals
Honestly it does run kinda hot so I would give it plenty of breathing room. Thats a lot of power for a class A/B, heats gotta go somewhere //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If it still interests you then you are next in line if my trade falls through
BTW, thank you nineball
I'm running a total of 920-1240w of A/B power right now. Or was, until my MB Quart fried itself, so I think it should be somewhat equal. After seeing the dimensions, I think it could work out well. It looks as if a lot of heat is dissipated along the edge, which would have a good amount of breathing room. As long as there wouldn't be an issue running the two sets of speakers off the front channels, it would solve my amp issues. I could get more power to my comps, probably not have as many heat issues and ditch my sub amp and keep the same power to the subs. If your trade falls through, PM me a paypal address, you've got a buyer. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
EDIT - May be a stupid question, but, can you run say, 2ohms on the rear channels and 4ohms on the front channels? I've never tried that before.
Yes you can mix and match front and rear channel impedance. All the heat is concentrated on the heat sink, so if that has sufficient room then it should be fine. Mines in a hot trunk right now so I am sure that doesn't help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BTW, nineball I live in California, so it is generally 90+ heat all day //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i don't think you can do that but i could be wrong. i would ask jason before you attempt it.
Why not? Its just like if you were to run the fronts at four ohms and bridge the rears at 4 ohms (effective 2 ohms per channel). Ive never had an amp complain when I do that.
Who is jason?
He is a Cadence rep, JasonPaul I think is his screen name either here or at diymobileaudio.com
Fast1one
Fast1one
California
nineball
