Sold FS: (4x50 alpine)(9603i 6x4 infinity)(5002I infinity 5.25)(scotch wiring kit)
On those infinity I meant 6x9
Everything is in like new condition. Speakers were used once and then put back in the box. Come with manuals. Amp was used for couple of months
Amp is MRP F-240 $100 + shipping
Details:
» 40 watts RMS x 4 at 4 ohms
» 50 watts RMS x 4 at 2 ohms
» 100 watts RMS x 2 bridged output at 4 ohms
» 2-, 3-, or 4-channel output
» 4-ohm stable in bridged mode
» Tri-way capable (Tri-Way Crossover required)
» requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
» selectable high-pass/low-pass crossover at 80 Hz, 18 dB/octave (2 separate crossovers, one for channels 1 & 2, another for channels 3 & 4)
» subsonic filter at 15 Hz for channels 3 & 4
» tuned Bass EQ (0-12 dB bass boost at 50 Hz) for channels 3 & 4
» preamp outputs
» MOSFET power supply
» STAR Topology (minimizes internal noise and prevents ground interference)
» speaker- and preamp-level inputs
» gold-plated screw terminals
» 10-1/2"W x 2-7/16"H x 9-9/16"D
Infinity Reference 5002i: $50+ shipping
» Plus One+ polypropylene woofer
» high-roll rubber surround
» textile dome tweeter
» frequency response 67-21,000 Hz
» recommended power range 2-45 watts RMS
» peak power handling 135 watts
» sensitivity 92 dB
» top-mount depth 2-1/2"
Infinity Reference 6x9 9603i $70+ shipping
» hi-roll rubber surround
» textile dome supertweeter
» frequency response 46-21,000 Hz
» recommended power range 2-100 watts RMS
» peak power handling 300 watts
» sensitivity 92 dB
» top-mount depth 3-5/16"
Unopened scoshe wiring kit $35+ shipping includes:
4ga to 2x8ga distro
MAXI in-Line Fuse Holder with 100 amp fuse
14ft., 5 ga. Power cable
6ft 9ga power cable
4ft 9ga ground cable
17ft remote wire
two 17ft clear audio cables
Connectors and hardware
Kit is rated up to 1400 watts max
Prices are negotiable and discounted if more then 2 items are purchased
hellomota
Banned
hellomota
Chicago burbs, IL
hellomota
