Sold FS: 4-10" Kickers & 1000 watt Amp
bmfp
Sittin Low as a S10
I am selling a 2 Channel 1000 Kenwood Amplifier KAC-7252
4 10" Kicker Comp's 05C10-4
The sub's arent abused but one has a little hole from my screw driver. Thats all the others are in GREAT condition.
The AMP is never turned all the way up and is in NEW condition.
Here are some specs on the subs:
Sensitivity: 87.3 dB
RMS Power Range : 50-150 Watts
Peak Power Handling: 300 Watts
Impedance: 4 Ohm
Low Frequency response: 30 Hz
High Frequency Response: 500 Hz
Diameter: 10 Inch
10" subwoofer with high-strength steel basket
Polymineral cone with double-stitched foam surround
mounting depth: 4-15/16"
Spring-loaded nickel-plated terminals
Works in free-air applications
Here is the Specs on the Amp:
RMS Power Range : 170-500 Watts
Number Of Channels: 1
Built In Crossovers: Yes
Channel Separation: Yes
170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
500 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
Wired remote control for bass boost and low-pass filter
high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
Bass boost (0-18 dB) variable from 40 to 100 Hz
Tri-way capable (Tri-Way Crossover required)
MOSFET power supply
CEA-2006 compliant
Cooling fan
Preamp- and speaker-level inputs
Preamp outputs
Requires 4-gauge power and ground leads
13-5/8"W x 2-5/16"H x 11-1/4"D
Asking $375 for subs and amp together.
Seperatly asking $225 for the SUBS and $150 for the AMP
Phone # 856-383-7716
Needs to Go ASAP
WILL TRADE FOR 1-15" sub w/ Amp or 2-12" Subs w/ Amp
bmfp
Sittin Low as a S10
bmfp
Bellmawr, NJ
audioatg
