Sold FS 300amp EA alt
bones22
used for about 4 months. works great just needs cleaned up (if you want it to look good)
will fit:
96-up GM (tahoe, yukon, jimmy, s10/blazer, astro, escalade, im sure there are others but yea)
4.3, 5.0, 5.7
its a large case but is direct bolt on for small/large case.
it does have the pigtail to replace the one with small cases
$325 shipped in the 48
so this will fit the small cause i have a 93 chevy with a small one on passanger side
yes it will it wont fit in a 93 without grinding a little off of one of the mounting ears of the alternator. easy to do just get an angle grinder take a little off at a time till it slides in. then just run a bolt thru with a lock nut on the rear.
my 97 tahoe had a small case but when i ordered i told nate i needed a large case. they mount exactly the same.
bones22
bones22
in my house
bones22
