Zapco 1100.1, Zapco Reference 1100.1
Both come with a cheap simbilink cable. Had to be filed down to fit cause its a Chinese POS cable
The Zapco 1100.1 is in great condition. Was mounted on the wall at an audio shop then installed in my vehicle for the last 2 weeks. Comes with box and birth sheet
cosmetically 9/10
functionality 10/10
The Zapco reference 1100.1 is used but was stress tested for over 24 hours and has also been installed in my vehicle for the last 2 weeks
Cosmetically 7/10 Missing mounts
functionality 10/10 The fan does run while off but that is normal and does not drain the power
Reference Series Monoblock Class A/B Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 825 watts x 1 chan.
2 ohms: 1100 watts x 1 chan.
Dynamic power output: 1450 watts x 1 chan.
Optically isolated MOSFET power supply
High current bipolar outputs
E.H.V High voltage output circuitry
Variable low-pass filter (55-550 Hz, 24 dB/octave)
Variable subsonic filter (24 dB at 15-50 Hz)
Damping factor: >700 @ 4 Ohm
CEA-2006 compliant amplifier
Frequency response: 20-20,000 Hz
Dimensions: 35"L x 7-1/2"W x 1-15/16"H
The minty 1100.1 425.00 shipped obo
The Reference 1100.1 325.00 shipped obo
Will trade one with cash, or both with cash for a great 3k amp @ 1 ohms
Fed Ex ground
Took this photo today on july 4th. will update a new one soon
cosmetically 9/10
functionality 10/10
Fed Ex ground
