Sold FS 2 MJ-18"s 4ohm
Power Handling: 600 watts RMS
Sensitivity: 93.4db (2.83 volts)
Impedance: 4 or 8 Ohms (SVC)
Outside Diameter: 46cm (18 1/8")
Mounting Diameter: 41.9cm (16 1/2"")
Depth: 20.3cm (8")
T/S Parameters - MJ-18 - 8 Ohms
Fs = 30.4 / 28 Hz
Re = 7.2 / 3.2 Ohms
Qes = 0.39 / 0.34
Qms = 3.41 / 4.99
Qts = 0.35 / 0.31
Mms = 219 / 229 grams
Rms = 12.3 / 8.1 kg/s
Cms = 0.100 / 0.14 mm/N
VAS = 243.8 / 208.4 litres
Sd = 1029.2 cm2
Xmax = 12 mm
Cone Diameter = 36.20 cm
4 ohm on the right
terra
terra
Yes
financethis
