(2) Aura 2" "Whispers"
25 shipped
Cool little drivers.
I never integrated them into anything really, but I did use them full range off of low power.
Not a high SQ application, but were pretty cool and they suprised me.
You could also use this as a midrange in a 3way setup.
Aurasound 33mm "Whisper"
Features:
Frequency 250 to 15kHz
Titanium dome
Underhung voice coil
NRT neodymium magnet system
Inherently shielded
Foam surround
Frame: 49mm square
Overall Depth: 29.4mm
Specifications:
Fs 250 Hz
Nominal Imp. 8 ohms
Power (RMS) 15 W
Re 6.4 ohms
Sens. 1W/1m 84 dB
X-max peak 3 mm
Qms 4.72
Qes 0.80
Qts 0.68
Vas 0.1 ltrs
BL 3.5 TM
Mms 1.04 gr
Cms 390 mM/N
Sd 13.2 cm2
Net weight 113 g
Max Exc. p2p 10 mm
VC diameter 33 mm
http://www.madisound.com/catalog/product_info.php?manufacturers_id=121&products_id=85&osCsid=2c656995dfdfedbaa5ba0bc89354b9c9
Thank you for your interest.
CT
25 shipped
Features:
Titanium dome
Inherently shielded
Foam surround
Frame: 49mm square
Specifications:
Fs 250 Hz
Nominal Imp. 8 ohms
Power (RMS) 15 W
Re 6.4 ohms
Sens. 1W/1m 84 dB
X-max peak 3 mm
Qms 4.72
Qes 0.80
Qts 0.68
Vas 0.1 ltrs
BL 3.5 TM
Mms 1.04 gr
Cms 390 mM/N
Sd 13.2 cm2
Net weight 113 g
Max Exc. p2p 10 mm
VC diameter 33 mm
CT
