As the title says i have two of them. They haven't seen much power, i only had them running for a month or two, and the amp i had for them just couldn't do them justice since i have the dual 2 ohm.
Wanting 225 shipped
Specs
Size (IN.,CM) 8, 20.32
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 900/450
Sensitivity (dB 1w/1m) 83.6
Frequency Response (Hz) 28-100
Mounting Depth (IN.,CM) 4-3/4, 12.1
Mounting Cutout, Square (IN.,CM) 7-1/4, 18.4
Min Rec Sealed Box Volume (CU. FT., Liters) .33, 9.4
Max Rec Sealed Box Volume (CU. FT., Liters) .75, 21.2
Min Rec Vented Box Volume (CU. Ft., Liters)** .66, 18.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 1.0, 28.3
These guys are pretty much brand new cos is 9.5/10 you can see from the pictures that they still look new and they function 10/10 There are no scrathes or any damage of any sort. They still even have the new smell
http://i809.photobucket.com/albums/zz19/kraudio/100_8420.jpg
http://i809.photobucket.com/albums/zz19/kraudio/100_8403.jpg
http://i809.photobucket.com/albums/zz19/kraudio/100_8404.jpg
Wanting 225 shipped
Specs
