1. Product:
18" TC Sounds Q1.4 complete sub (broken basket and rips on the surround)
Like New 15" 5200 basket
BRAND NEW 15" Carbon Fiber Cone (Just needs a dustcap)
Spare 5200 Coil and Spider.
(Got this in on trade and couldn't tell you how the 18 cracked the basket and surround, some quicksteel should fix it.)
2. Specs:
Advanced FEA Motor System
- Triple stacked 3/4" tall ferrite magnets and long T-yoke
- Massive 390oz top grade 10.1" wide magnet super structure
- Large anti-flux modulation aluminum shorting ring to lower distortion
- Low carbon steel used for the gap plate and t-yoke
- Large pole vent for lower distortion and cooling capabilities
Advanced high excursion soft part system
- Dual stiff high excursion 10" linear roll poly-cotton spiders
- Extra thick integrated woven leads to prevent lead-slap
- Quad lead wires decreases lead wire resistance to improve heat dispersion
- 4" diameter, 8-layer flat aluminum wire voice coil with an aluminum former
- Extra spacing in-between spiders for lateral stability
- Quad 1.2ohm (1.5 ohm nominal) voice coil configuration
- Ultra strong, brushed and powder coated titanium cone (TC Sounds exclusive design)
- 1" wide long throw tall profile, highly durable NBR surround
- High quality thermal flexible epoxies to ensure longevity
Patented custom cast aluminum frame
- Extra clearance under the suspension for dynamic high excursions
- Wide spider landings for higher than average throw
- Patented tooless detachable method for easy and fast and recones or repairs
- Durable high gloss black powder coat and chrome vc mesh guards
Performance
- Effective motor force of a staggering 410 Newtons2 per watt (BL2/Re)
- 2000 watts continuous power (6000 watts peak)
- 30mm BL XMax (voice coil, one-way)
- 46mm XMech (mechanically limited, one-way)
15" TC-5200 QVC
Qts 0.159
Qes 0.164
Qms 5.1
Fs 22Hz
Res 4.52Ω
Ls 6.56mH
Lp 10.6mH
Rp 13.7Ω
Dia 315mm
Vas 109l
mms 517g
cms 109um/N
bl 43T*m
Spl 90.2dB
3. Description/Condition:
4. Price: :
$720 for all of it + Shipping.
Or
The 15 built with no dustcap for $650 + shipping
6. Pictures:
All of it together
Another pic of everything
The crack in the 18" basket
The 4HP Motor
Backside of the 18" basket and cone.
The Blue 15" basket.
The 18 Next to a 21" Death Penalty Basket and Motor (Which is also for sale)
2. Specs:
Performance
15" TC-5200 QVC
Qts 0.159
Qes 0.164
Qms 5.1
Fs 22Hz
Res 4.52Ω
Ls 6.56mH
Lp 10.6mH
Rp 13.7Ω
Dia 315mm
Vas 109l
mms 517g
cms 109um/N
bl 43T*m
Spl 90.2dB
4. Price: :
Or
6. Pictures:
All of it together
The 4HP Motor
