FS: 15" Sundown Nightshade V1, 2 Eclipse SW8122.4 SVC, TC9 Driver w/ Red Basket
Drummer65
15" Sundown Nightshade V1: Good condition, Never seen anything over 2500 watts. Cosmetically 8/10, Mechanically 9/10
Dual 2-ohm or Dual 1-ohm Voice Coils Available
3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
High Temperature Aluminum Voice Coil Former
1500-Watts RMS Power Handling
Over 2 inches peak to peak excursion
Wide, triple-layer foam surrounds for high excursion
Extremely strong paper cones w/ stiffening disc
Thick poly dust caps
Cast Aluminum 12-spoke basket with cooling vents
Triple Stacked 1" x 9" magnet slugs for high motor strength
MSRP - $679 USD
T/S D1 **:
RMS: 1500 Z: 2 ohms
Re: 2.18
Fs: 37 Hz
Qms: 7.86
Qes: 0.46
Qts: 0.43
VAS: 36.6 L
BL: 19.44 NA
T/S D2 **:
RMS: 1500
Z: 4 ohms Re: 2.92
Fs: 38 Hz
Qms: 8.64
Qes: 0.46
Qts: 0.44
VAS: 36.6 L
BL: 22.8 NA
- 2 Eclipse SW8122.4 SVC: Great Condition, Very Nice SQ subs. Cosmetically 9/10, Mechanically 9/10 500 Watts rms but can easily handle 700-800 rms.
- TC9 Driver w/ Red Basket Was a Eclipse 88120 but the cone separated from the voice coil damaging the cone. Still has the voice coil, spider ect attached just needs a cone.
15" Sundown Nightshade V1: $250 + Shipping
2 Eclipse SW8122.4 SVC: $85 each + Shipping
TC9 Driver w/ Red Basket: 60 + Shipping
before i took them out i had them sealed on a Orion 2500d. Sounded amazing and still had great output. I've never heard the P10 but i can they would match if not beat the output of them. I hit a 143.8 with four of them
Drummer65
Drummer65
Newport Beach, CA
Drummer65
