Sold FS: 13-18 Volt 300 amp Ford alt.
JG903
I have a used 300 amp alternator from H.O. alternators and is externally regulated. You can set the voltage from 13 to 20 volts using the external voltage regulator by just turning a knob. It is a simple 3 wire hook up. I am looking for $350 shipped and insured for both the alternator and voltage regulator. The alternator will ship with original packaging and box. It is a 6G ford alt and will fit some vehicles.
1998-2004 MARQUIS 4.6L
1998-2004 LINCOLN TOWN CAR 4.6L
1998-2004 CROWN VICTORIA 4.6L
MARAUDER 2003-2004 4.6L
1999-2004 MUSTANG 4.6L ORIGINALLY EQUIPPED WITH THE 105 AMP ALTERNATOR
Some 2002-2005 FORD PICK UP & EXCURSION 5.4L & 6.8L
or just build some brackets for it.
Sorry if the pics are a little big.
Could it be modified to fit 96 gmc safari van 4.3 liter
In order to fit the safari you would probably need to make brackets for it to fit. I have a silverado truck and made the brackets and had dual alts as you can see in the picture. Making brackets is not the easiest thing to do. And sometimes you just don't have room for it.
JG903
JG903
Jacksonville, TX
slapmaster
