Sold FS: 06-09 Honda Civic High Output Alternator 200/120amp Cheap!
mike11202
I have here an Excessive Amperage 200 amp alternator (with 120amp idle) it was listed 200/120. I used it for about a year when I was running over 3,000 watts. I downsized so I no longer need this alternator.
If you need to build up a good charging system, this will work great. Stock Alternator is only 90amp.
Alternator is in great shape for being used (see pics), there is very minor mounting wear on the bottom (can't be seen when installed). It runs great no problems at all and also has an underdrive pulley.
Works with Honda Civic Dx, LX, EX 06+
Looking for 199 shipped.
An underdrive pulley? The alternator has a larger pulley on it which underdrives it so it puts out less power? Or do you mean it has a smaller pulley which spins faster, a.k.a. an overdrive pulley?
Hi I am interested in your alternator you probably sold it but if you havent can you please let me know. And if you did sell it would you be able to tell me where you got it. I am running alot of audio and visual equipment and need a high output alternator 200+ amps. Hope to here from you soon thanks.
Jonathon
Phoenix, AZ
mike11202
mike11202
DE
Louisiana_CRX
