Fronm one extreme to the other
G8or76
CarAudio.com Newbie
7
GA
On a previous thread I inquired what to do with an amp to sub situation where my amp lacked the recommended rms.600 watt max amp to 12" L7 rms 750. I received quick and dead on info as to how to get the most out of what I had. Well ive come into ownership of a acoustik bamf 4000/1D so im coming back asking what's the best way to set this amp as to get the best out of both without killing one or the other.
Which L7 do you have? Dual 4 or dual2?
I'd also like your input on how do I wire dvc 4ohm to an amp thats ideal setting is 4ohm?
You only wire up one coil as wiring up a single voice coil sub. This is a Double 4 ohm Voice coil sub so only using one coil will be a Single Voice coil sub woofer at 4 ohms. Thus.. you can only give the sub woofer 1/2 the RMS value/RMS rating.Example= If its a 600 RMS DVC 4 ohm sub, and you use only one coil, then you only place 300 RMS on that one coil for 1/2 of its RMS Value/Rating
How about when you're dealing with an amp that has no certification available so therefore non reliable numbers Accoustik bamf 4000/1 D 1200 watts rms @4ohms 1700 rms @2ohms 2200 rms @1ohm and a absolutely reliable KICKER L7 dvc 4ohm subwoofer listing rms at 750 and max at 1500. If i wire the way listed a svc my subs power is cut in half in this case say 350 watts but doesn't alter the amps power. My original question was how to put 750 watt sub and 1200 watt amp together without losing either in the process.
Wire it up to a 2 ohm load and tune accordingly.Get the Big 3 done/recommended, and enjoy
G8or76
CarAudio.com Newbie
G8or76
GA
audiobaun
