From YOUR experience!!! What gets lower 12 SX or XXX
SX is more efficient than the XXX, XXX gets LOW, the SX isnt know to have the best low end though, but it suffices
and it is only 1 12, if you want it to extend lower or be more pronounced in the lowend tune to 25hz or so
and yes ive owned a SX and XXX, XXX seems to me to be lacking on the upper end, but its all in the install, good mid bass woulda help out alot
so bama what would you recommend? i like the bass i have now kinda hits you in the chest at first till you get used to it but im lacking those lows that are heard down the block which is what im looking for.
what is the vehicle? how many watts are you running
how much space would you be willing to give up
an used XXX 15 would probably give you what you want, or an I dont know what an SI mag sounds like, but the way everyone talks about them, they would be right up your alley, maybe a SS RL-P too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
give some info real quick
in my personal expireience ive found the Brahma to play lower than the xxx, the xxx is louder overall however. both brahma's ive owned have been low end monsters. but im sure the xxx will do just fine, just tune the box low(25-28Hz) try around 3cubes@25Hz... for a 12 and you should be impressed
well its a 96 2.5 TL and i cant fit a 15 in a ported box in my trunk
i can if its sealed but the sub has to fire up (i had a CVR like that)
Theres a lot of space just a small opening and seats that dont fall down
for example blue berry yum yum and Hoods Run Down and some others like them that are meant to get low (and ive heard low) dont do justice in with my sx12
blueberry only goes to like 35-37 or does it go lower?
to be able to do hoods safely, you need a sealed box or a way low tuned ported, because some of those notes go down to 15-16hz or so i believe
dadeschevyboy
dadeschevyboy
MIAMI-DADE COUNTY
dadeschevyboy
