thur5d4yf4n
well i just need to know what size aeros I should use for the best tuning.. i want these 8's to get low and loud. or any tips on the total cubic ft for all 4. fry's electronics had a deal on these where they are half off to start with then if you buy one you get the second half off so i paid $182 for four 8's that came with 3 year full replacement warranties on each sub. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif oh yeah i'm wiring all 4 onto a diamond audio d3 800.1 @ 1 ohm. 200 rms per sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
any help is great.
here's specs
Driver Complement
Woofer 1 - 8" Diameter (20.32cm)
Metalized (aluminum) Polypropylene Dynamic Balance cone
Electrical
Overall Frequency Response 26Hz-200Hz
Nominal Impedance 4 ohms
Minimum Impedance 3.3 ohms
Power Handling (continuous) 200 w
Power Handling (peak) 400 w
Efficiency 85 dB
Voice Coil Diameter: Driver 1-1/2" (3.81cm)
Magnet Weight 25.00 oz.
Driver Mounting Depth
Top Mount 4-1/4" (10.79cm)
Bottom Mount 4-9/16" (11.59cm)
Cut-out
Driver Cut-out Diameter 7-1/16" (17.94cm)
Theile/Small Parameters
Recommended Enclosure Sealed / Ported / Bandpass
Resonant Frequency 43 Hz
Qms 15.13
Qes .68
Qts .65
Vas 0.562 cu.ft./15.9 L
Bl 10.2 Tesla Meters
Sd 34.72 sq.in. / 224 sq. cm.
Xmax (linear) .709 in. / 18 mm.
Le 1.84 mH
Other
Product Weight 9.00 lbs.
any help is great.
here's specs
Driver Complement
Electrical
Efficiency 85 dB
Cut-out
Qms 15.13
Qes .68
Qts .65
Le 1.84 mH
Other
