four(4) polk GXR 12inch subwoofers. BRAND NEW IN THE BOXES.
150 dollars for all four. buyer to pay shipping.
any questions email me at MMM0513@comcast.net
Thanks
Matt Musto
*---* SPECS *---*
Driver Complement
Woofer 1 - 12" Diameter (30.48cm)
Poly/Mica
Electrical
Overall Frequency Response 25-400Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 165 w
Power Handling (peak) 365 w
Efficiency 90 dB
Voice Coil Diameter: Driver 1-1/2" (3.81cm)
Install Dimensions
Full-range Mounting Depth
Top Mount 5-1/4" (13.34cm)
Bottom Mount 5-5/8" (14.29cm)
Cut-out
Driver Cut-out Diameter 11" (27.94cm)
Theile/Small Parameters
Resonant Frequency 25.91 Hz
Qms 7.75
Qes 0.50
Qts 0.47
Vas 4.83ft3
Sd 82.29in2
Xmax (linear) 0.24
Le 1.32 mH
Thanks
Matt Musto
*---* SPECS *---*
Driver Complement
Poly/Mica
Electrical
Efficiency 90 dB
Install Dimensions
Cut-out
Qms 7.75
Qes 0.50
Qts 0.47
Vas 4.83ft3
Sd 82.29in2
Xmax (linear) 0.24
Le 1.32 mH
