irnotfob
So i have hadthese crystal subs laying around for a while and was considering porting it in the back of my Accord. I found the box calculator on REs website quite helpful and when it comes to ported enclosures im clueless. but here is what i have. Roughly 6 cubes @ 32. I was wondering how this would sound. I'm looking for loud with some sq.
Here are the dimensions of the box that i got from the RE website:
box width = 35
box height = 30
box top depth = 15
box bottom depth = 15
wood thickness = 0.75
square port height = 28.5
square port width = 3
square port length 1 = 11.25
square port length 2 = 12
total port length = 28.5
box volume (ft3) = 6.039
tuned frq = 32.487
and here is the only information on the drivers i could find. These are Crystal PROst subs SVC 4 ohm. I will be running these to my RE 12.1
· 12 “ Cast Aluminum Basket
· 4 Layer Voice Coil
· Butyl Rubber Surround
· Woven In-Spider Tinsel Leads
· Bumped & Vented Back Plate
· 5-Way Binding Posts
· Fs 22.252 Hz
· Re 3.6 Ohms
· SPL 86.95 1watt / 1M
· Qms 4.185
· Qes 0.319
· Qts 0.297
· Vas (Sd) 63.952 Liters
· Bl 21.845 Telsa-M
· Power Handling 300w rms
· Recommended Enclosure: 1.2 cu. ft. sealed
· Mounting Depth 5.25 in.
Any suggestions are greatly appreciated. I really need some input on this and i am really unsure on if the box will be big enough to go ported with these subs. If i definetely need a bigger box than i might as well stay sealed because the dimensions of the box is the maximum area i have to work with to fit in my trunk.
box width = 35
box height = 30
box top depth = 15
tuned frq = 32.487
· Fs 22.252 Hz
· Re 3.6 Ohms
· Qms 4.185
· Qes 0.319
· Qts 0.297
· Bl 21.845 Telsa-M
