Found an oscilloscope, have a few questions.
  • 2
DirtyDuzit
AZ
So my mom used to own a thrift store and to make a long story short I found a oscilloscope in one of her storage containers.
It's a Tektronix 2213A 60MHz scope.
It turns on and seems to work but I have a few questions.
1. I don't have the probes for it, are they universal? I see sets for as cheap as $8 on eBay.
2. Will this work for car audio? I've only ever used the SMD clipping indicator.
Nice find.  You need the leads, and there are two main kinds:   standard or 10x.  The 10x leads let you measure higher voltages.
Note that you connect the ground lead on the scope to chassis, not signal ground, when measuring audio signal.   There are a lot of videos on using a scope to measure for clipping.
I have a video on using an RTA to measure clipping and response - and it shows you what you can expect (since my RTA software has a scope mode).
Thanks I'll check that out
I'm currently writing an Instructable with a new video showing how you can use an RTA program with oscilloscope functions and frequency response.  It goes into more detail than the video above, but uses the same program.
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Dammned good amps. I ran that series for years. I just sold my last GTQ400 last year. I still have a GTS600 left. that series will run up to 16v...
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
989
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
DirtyDuzit
AZ
keep_hope_alive
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
