Fosgate t3002
alexandergpace
Anyone who has had this amp or knows about it..i need help configuring it. To 12' alpine type E subs. I dont know anything about high pass or low pass freqs. or what freq. to use in general. any help is appreciated. thanks. I listen to heavy bass music and want the subs to slam optimally with out blowing.
Do you already have them hooked up to the amp? If so, what configuration (4 ohm, 2ohm, etc)? If you need help with that just ask too. As far as low or High Pass. You will not be using the high pass because you have subs wired to it. Use the low-pass and as far as setting it...look at your specs for your subs as far as freq...tune it based on that and the box in your car. I recommend staying at or below 80hz. Make sure you do not just max out your gains on your amp. Take it down to a shop or use a DMM to set your gains properly. If you want to do it yourself there is a Gain Setting Tutorial on this forum.
Here's the manual for that amp. I suggest you read it to get more info:
http://www.rockfordfosgate.com/rftech/library/2005/3_Amplifiers/1230_51197_01_RF_T3002_T4004-MAN.pdf
alexandergpace
alexandergpace
Dallas
lionfamlee
