nickolas_j_t
I approve this message
Its a T1500-1bd amp. would that be good for two fosgate t1 subs that are 600 rms each?
I would say so. Long as you have dual 4's. The only other punch amp I could think of would be the 1000-bd, but headroom is a good thing. I think there a good match.Would that be the best thing probably for them?
Thanks man. If your wanting a 1 ohm load and your running two subs you need dual 4 ohm subs wired in series/parallel into the amp. Basically wire each sub down to 2 ohms and put the pos and neg into the amp.so i should get dual 4's? and im lovin the crown vic. im a fellow ford man too.
