aren't they only warrentied if run at .5 with mags though?is there a point in paying $369 extra for a ia20.1 over a sundown?i mean 300 rms isn't worth that much in my book. also i know most buy the ia inorder to run under 1 ohm but now that sundown is warrentying people running at 0.5 ohms now so ......
ROFL NO why would they underrate it 1200 watts seriouslya 20.1 will do about 4k @ .25
and i think they've been known to do over 3k at 1ohm but im not sure where i heard that so it might not be true
nope not anymorei thought it was under warranty below 1 ohm IF it was paired with an SI product?
but yes i agree not worth that much extra money
i'm sure i've seen it tested and coming up with almost, if not, 3k.ROFL NO why would they underrate it 1200 watts seriously
that did make me chuckle alittle inside, specially since it was already pointed out why they'd underrate amps in this thread before thatare still rolling on the floor or did you read what i posted
im still rolling on the floor, because i've had 2 and niether came even close to 3k watts at 1ohm. i'd like to see the test or grph of someone who runs them at 3k watts at 1ohm at a regular voltage, not somethign like 16v or 18vare still rolling on the floor or did you read what i posted
I remember a showdown between the 20.1, 2500D, and the SX 2500.1(maybe KX line). And the 20.1 was beat out by both the orion and the kicker at 1ohm, and did low 2000's at 1ohm, IIRC. But if you can show me where is put out ~3000 then you can shut me up.if you don't know why they would underrate it then you don't know much,
a vfl 150 is rated at 150 watts but will do close to 4k(.33 ohm, 18v)
