Sundown e8v2 dual 2 ohm sub and dayton 240 watt at 4 ohm plate amplifier
and blackberry bold body glove case
THESE GO GREAT TOGETHER
sundown e8v2
Rated RMS Power = 200 watts
Mounting Depth = 4.25"
Outside Dia. w/gasket = 8 5/16"
Inside Dia. 7.000"
Sealed Box: 0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box: 0.60 ft^3 tuned to 30 Hz F3 of 25 Hz
MSRP - $99
T/S D2 **:
RE: 6.12 ohms
Fs: 44.7 Hz
Qes: 0.5456
Qms: 3.6545
Qts: 0.4748
Le: 4.02 mH
Vas: 7.26 L
BL: 17.45 NA
Cms: 131 uM/N
Mms: 96 grams
Sens: 82.59 1w/1m
Xmax: 10.5mm one-way linear
Power: 200 RMS
Dayton plate amp
Overview
The Dayton Audio SA240 subwoofer amplifier features adjustable crossover, high and low level inputs, auto on/off and phase reversal switch while offering very stable operation with full overload protection.
Highlights
High power/low distortion for crisp, clean power
Adjustable low pass crossover
High and low level inputs/outputs accept a variety of audio sources
Auto On/Off helps you avoid fumbling with power switches
Phase reversal switch allow for optimized room placement
Power output: 170 watts RMS @ 8 ohms 240 watts RMS @ 4 ohms
S/N ratio: 90 dB (A-weighted)
Took both out of the box basically lnib no flaws tested both to work just dont have a need for them got them in a trade.
The e8 goes for 90 new so ill ask 70 plus shipping
The dayton amp goes for 130 to 140 so ill ask 110 plus shipping
Body glove for 15
Ill take 150 for both if bought together
BUYER MUST PAY SHIPPING
sundown e8v2
Inside Dia. 7.000"
MSRP - $99
T/S D2 **:
RE: 6.12 ohms
Fs: 44.7 Hz
Qes: 0.5456
Qms: 3.6545
Qts: 0.4748
Le: 4.02 mH
Vas: 7.26 L
BL: 17.45 NA
Cms: 131 uM/N
Mms: 96 grams
Sens: 82.59 1w/1m
Power: 200 RMS
Dayton plate amp
Overview
Highlights
Body glove for 15
