ford fusion hybrid
i did relocate ground and sanded for bare metal, it works fin while running off battery but as soon as it kicks the engine on the low rubble will stay on.
there is no whine just a continuous rubble the whole time while the car is running, i also re-ran all the wire to avoid any noise. i heard of the active noise sensors in the car but thought the lc2i would clear that out
no its a se hybrid no equipped, i have a kicker amp and the lc2i ground is with the same ground of the amp to the metal frame in the trunk
Hmmm. I would probably try running a ground from the LC2i to the battery as a test. Just run a long ground wire outside directly to the battery. See if anything changes. Another thing to check would be your gains on the LC2i and the amp. Gain should be pretty low on the amp since the LC2i has up to 9.5 volt rca output.
ok i will try to relcate the ground and i gains are off on the amp so i will check the lc2i thanks for the help i will update if anything changes
redsox1
CarAudio.com Newbie
redsox1
redsox1
Mike Mccabe
