~Bay Area transactions only~
For sale is a slight used, but perfectly functional resonant engineering 12" SE subwoofer. Specs are as followed:
12”
Mounting Depth - 6.5”
Mounting Hole Diameter - 11”
Overall Diameter - 12.5”
Bolt Hole Circle - 11.75”
Motor Width - 6.25”
Motor Depth - 3.25”
Basket Depth - 3.25”
Displacement - 0.15 cu. ft.
Weight - 21 lbs.
Electrical Q Value -Qes: 0.49
Mechanical Q Value -Qms: 4.5
Total Speaker Q Value -Qts: 0.44
Free Air Resonance -Fs: 25.1 Hz
Equivalent Compliance -Vas: 72.9 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 86.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Box dimensions are:
Height: 14 in.
Length: 17 in.
Width: 16 in.
Gross displacement: 2.203 CuFt.
Net Displacement: 2.054 CuFt.
Pictures:
Slight nick.
Price: ~ $165.00
Any questions or concerns can be addressed in this thread or by private messages.
Jason C.
12”
Motor Width - 6.25”
Motor Depth - 3.25”
Weight - 21 lbs.
Box dimensions are:
Height: 14 in.
Length: 17 in.
Width: 16 in.
Pictures:
Slight nick.
Price: ~ $165.00
Jason C.
