Sold FOR SALE: Arc Audio KS125.2 Mini and Orion 800.1
JonMR2turbo
Arc is sold.
And the 800.1 specs:
# Power Output in Watts RMS, 4 Ohms 300 x 1
# Power Output in Watts RMS, 2 Ohms 400 x 1
# Externally Bridgeable: yes
# Remote Gain Function: yes
# Distortion at Rated Power
# Frequency Response 20Hz to 30kHz +0, - 1 dB
# Linear Bandwidth 20Hz to 20kHz ᄆ3dB
# Damping Factor > 150
# Input Sensitivity rms
# Input Impedance 80kOhms
# Fuse Type : (2) 30 Amp ATC
# Dimensions : 13.4" x 8.1" x 2.1"
# Weight: 7.3 lbs.
# Low Pass and Hi-Pass Crossover Continuously variable / 2nd Order
# Low Pass Frequency Range 50Hz to 500Hz
This amp is also pretty much brand new, in mint condition. I've had it for about 4-5 weeks as well. I'm selling it because I was going to power a single BM with it but now I have room to get two of them and it isn't stable to 1 ohm so it's got to go. Asking $140 shipped.
Sorry the quality sucks, I only have my cell phone camera.
I have the manual and line level inputs for both amps but they will be shipped separately because I just moved to Florida and left them at my parent's house.
Up for a fellow/former MR2 owner. :p
A little off topic, so it may be better discussed through PM, but I saw, while doing car audio research, that you have/had CDT components. Which ones did you have, and how did you like them? Speakers are the only item left of my build that I have to purchase before I can start piecing it all together.
Regarding the Arc... I came pretty close to buying an Arc, but the 125.4 Mini was not available yet, so I picked up an Alpine PDX-4.100. Good luck with your sale. That's a great amp.
Hey do you post on mr2oc? I'm not an owner for much longer though...I just picked up an SC400 last week.
I had the CL61A's. I liked them alot but the midbass was a bit lacking. Then I got PG RSDs which sucked in comparison. I am going back to CDT and will be getting the HD62s as soon as possible to put in my SC. Send a PM to "exige". He is a dealer and was very helpful in helping me pick a CDT set. He can even let you customize them.
JonMR2turbo
JonMR2turbo
Florida
motoxlrg
