Focal Solid 1 black mono $145 shipped
gentlejax
Item(s) for Sale:focal solid 1 monoblock black
Item(s) Description/Condition:missing wire covers otherwise in excellent shape.
sounds better than the clarion dpx1851 I had or the JL XD 600/1 I had. I think it puts out more than rated but I only ran it 4ohms.
Solid Series Monoblock Class A/B Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 300 watts x 1 chan.
2 ohms: 470 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +9 dB bass boost at 50 Hz)
Soft Start Turn-on
Mono channel operation
Speaker-level inputs with signal sensing for automatic turn-on
Bass remote level input and control included
Preamp RCA outputs to daisy chain multiple amps
4-Way System Protection circuitry (polarity reversal, thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Input sensitivity:
Low level: 200mV-5V
High level: 400mV-9V
Variable low-pass filter (50-150 Hz, 12 dB/octave)
Subsonic filter (24 dB at 35 Hz)
Phase Shift: 0-180°
Damping factor: 50-50 Hz @ 4 Ohms
CEA-2006 compliant amplifier
Frequency response: 10-150 Hz
Dimensions: 11-13/16"L x 7-7/8"W x 1-3/4"H
4-gauge power and ground wiring is required for installation
Price:$145
Is it 1 ohm stable?
doesnt list it as such so I would say no
I just know it is rock solid. I got it from my engineer tech who repairs and designs equipment. He loved it but sold it to me when I was looking for a monoblock that wouldnt **** the battery. He like this amp better than the JL slash 500/1 he was using in his work beater
I said it doesn't list it as such so I wouldn't advise it.
I know the JL shady amps are rated 1ohm but I know my repair tech says they really aren't and that burn up. So this one I wouldn't try that.
I have a us amps ax600de that is rated 1ohm and it states will do it fine. Don't know if I want to run it that hard though
gentlejax
gentlejax
Bossier City, La.
gentlejax
