is the K2 line the top focal has to offer? im not familar with the focal line-up. also, if they are not the top line they put out, around where would they be rated?
The K2 line is right under the Utopia line. Very good components have owned the 165kp the older version of the k2s. You cant go wrong with either set considering location and power.
Prober you just cant make up your mind for some components can you. My advice is check out some local shops, and listen around to see which one you like the best. If not that then find a good audiophile company, and try a set of components. Good luck
The K2 powers are some of the best sounding compoents I have ever heard. Im getting a set shortly. You need to run them off a very clean amp to get the best out of them. I heard the off a AUDISONamp all I can say is wow. I allso heard them off a PG TANTURM 600 watt 4 channel amp same power as the AUDISON and they didnt soun as clean or viberant. So if you looking for high end compents dont go with a cheap amp or you wount get the sound you should get from em.
