Fixing Rust
surface rust or rust that ate a hole? If its surface rust use sandpaper or a grinding brush on a drill to take it off. If it ate a hole you can do the cheap way and bondo it if it isnt bad or you can go to the junk yard and cut out a patch panel, weld it in, then put a skim coat of bondo on it.
DjiNN
Posts but still a NooB
DjiNN
Brooklyn, NY
brtnboarder3241
