First fiberglass project
Good Job! //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
How many layers of f/g is that?
Around 10! Since this is my first work with glass ever, I have no idea how strong it should be so I wanted to make sure.
dont even bother with the epoxy. just mix up some quality bodyfiller (rage gold?) and throw it on with a credit card, or body spreader.
id sand the whole thing with some 60, and clean in off before i add ANY bodyfiller though. id also fill the inside with resin\fumed silica before i did anything to the outside (dont wanna have to re-sand any drips )
lookin promising though!
I am planning on doing the resin/filler with some added strands as well before I do the outside for sure. Do you think I should cut out the wrinkles and lay something over to get it a little more smooth? Or should the puddy work fine? The wrinkles are around 1/8" to 1/4" deep.
If you feel that the body filler may not hold, which I think your fear is very possible, then you can use somthing called kittyhair, or duraglass, its bodyfiller with strands mixed in and is much stronger then just body filler....
Cajundude
Cajundude
Kemah, Texas
Buckshot
