Finally ordered them..
What type sandpaper to use will be decided on based from what you want the finish to look like.
If you want a mirror reflection, it will take a lot of sanding and time with many different types of paper.
What I have done in the past is like this:
I first sand the wood down with 60 grit then 150 then 220. I prime the enclosure usually with an automobile spray on primer. I usually do about 3 coats sanding with 220 lightly between coats. I then apply the first coat of paint very smoothly and evenly. Depending on what type of paint it is will decide whether or not I sand the final layer of paint. Most of the time, I don't sand the paint and just make sure the layers are light and even. I usually use a polyurethane clear coat as it can look good, it's easy to apply, and because it's pretty tough.
With the polyurethane, I start by thinning it out with a little bit of mineral spirits (about 70/30 poly to spirits). I apply the first coat pretty thin and let gravity settle things. I usually do about 2 to 3 coats like this before sanding to make sure I won't sand into paint. If you thin the polyurethane, the coats go on a little thinner but flatten out easier and you get less run lines. Don't try to apply a coat on any vertical surface as you will get runs and they will be a ***** to sand out. After 3 light coats, I wet-sand starting at 220grit until there are no shiny spots left on the surface and without sanding into the paint. I then wet-sand with ~400 girt then 600. After the 600, I put on a few more light coats of polyurethane. At this point, if things have gone well in application, I only need to use the 400 grit and 600 grit. If I'm satisfied with the finish after one more thinned coat of polyurethane, I lightly wet-sand with 600 grit then 1000 grit and then 1500 grit. That should kill all the shine and leave the surface without any deep scratches. I then put the final coat of polyurethane on and when it dries, I will lightly wet-sand with the 1500 grit. After curing for a few days, I use an auto rubbing compound then a fine swirl remover compound and then a wax.
The results can be very nice if you take your time and be gentle.
Here is a picture of a gloss black finish I did on a recent build. It's not perfect but came out **** nice.
you use that to "hear 10 hz"?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Nope, I use that to reproduce 10hz. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That helped out a lot bro, that enclosure looks great I def hope mine will come out half as good as that one lol.
The key is patience and applying thin and even coats of finish. This may sound ghetto, but on that finish, the last coat was applied with a bounty towel folding into a square and just barely braised the surface. All the other coats were done with a brush that said it was good with polyurethane... I know nothing about what makes a good paint brush; I just spent about $10 on one and kept it clean.
TC2k15x2
TC2k15x2
Debary FL
Glock23
